[GRASS-dev] [GRASS GIS] #109: wxgrass - d.vect and d.vect.chart: changing default checkbox options in GUI results in KeyError
results in KeyError
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Keywords: wxgrass d.vect KeyError |
The command line for d.vect displayed in properties window of a vector
layer does not correspond to the options displayed by the GUI. E.g. add a
new vector layer and chose a map (I'll use fields@user1 here). The command
line shown at the bottom of the properties window shows d.vect
map=fields@user1. This is fine as it means that for all other options, we
use the default. For the type option, the default is
"point,line,boundary,centroid,area,face" and this is what is shown in the
GUI where all the check boxes are ticked. However, if I uncheck any of
these boxes for the first time, I get the following type of KeyError:
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/etc/wxpython/gui_modules/menuform.py", line 1252, in OnCheckBoxMulti
del currentValues[ theValue ]
KeyError
u'point'
OR
KeyError
u'shape'
The same happens with the d.vect.chart type options.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/109&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
results in KeyError
  Reporter: mlennert | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords: wxgrass d.vect KeyError
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Replying to [ticket:109 mlennert]:
> KeyError
> u'point'
> OR
> KeyError
> u'shape'
It seems to me I have fixed this issue some time ago, see r30478. I tested
d.vect GUI dialog, no !KeyError. ??
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/109#comment:1&gt;
results in KeyError
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxgrass d.vect KeyError
Changes (by mlennert):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Just tried again and cannot reproduce. Don't know what happened...
Closing bug as fixed.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/109#comment:2&gt;
