[GRASS-dev] [GRASS GIS] #1122: Command line hangs where dialog boxes work
Reporter: JonBall | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows Vista
      Cpu: Unspecified |
When trying to use the command line to test the fix of Ticket #809
(http://trac.osgeo.org/grass/ticket/809#) , commands at the command line
all appear to return the error "Bad file descriptor: Files" error.
However, if you just type the command name without parameters you get a
dialog box. Using the dialog box to perform the exact same command
results in no error.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122&gt;
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: => wingrass
Comment:
Which version are you using? Please try out daily builds of WinGRASS
http://josef.fsv.cvut.cz/wingrass/grass64/.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122#comment:1&gt;
Priority: major | Milestone: 6.4.0
Component: Default | Version: 6.4.0 RCs
      Cpu: Unspecified |
  * priority: critical => major
Comment:
Replying to [comment:1 martinl]:
Downgrading the priority due to unclear status.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122#comment:2&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1122 JonBall]:
closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass
  Platform: MSWindows Vista | Cpu: Unspecified
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
no feedback for a year+; haven't heard noises about the issue from anyone
else, presume whatever was the problem is now fixed.
reopen if needed.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1122#comment:4&gt;
