[GRASS-dev] [GRASS GIS] #1123: Cairo driver dies unexpectedly after d.font
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: minor | Milestone: 6.5.0
Component: Display | Version: svn-develbranch6
Keywords: cairo | Platform: Linux
      Cpu: x86-64 |
working in 6.5svn, the Cairo driver dies unexpectedly a command after I
call d.font.
G65> d.mon start=cairo
cairo: collecting to file: map.png,
GRASS_WIDTH=1026, GRASS_HEIGHT=903
Graphics driver [cairo] started
G65> d.font Vera
G65> d.barscale at=7.992203,5.862832 bcol=none
ERROR: Cairo_draw_bitmap: Failed to create source
sometimes it also gives this error message:
ERROR eof from graphics driver.
and the driver is then closed. without d.font it all works fine.
libcairo2 1.6.4, in debian/stable amd64
haven't tested on other branches yet.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1123&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1123 hamish]:
call d.font.
lib/cairodriver/Draw_bitmap.c needs sync'ing with 7.0. It can't be merged
due to other changes to the driver architecture, but it shouldn't be too
hard to take the 7.0 version then tweak it for 6.x.
Cairo typically requires surfaces to be word-aligned. Older versions would
create unaligned surfaces which produced garbage when used as a source.
Newer versions simply refuse to create them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1123#comment:1&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: cairo
  Platform: All | Cpu: All
Changes (by glynn):
  * status: new => closed
  * platform: Linux => All
  * resolution: => duplicate
  * cpu: x86-64 => All
Comment:
call d.font.
Duplicate of #1152. This one came first, but most of the useful discussion
is on #1152.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1123#comment:2&gt;
