[GRASS-dev] [GRASS GIS] #1126: grass 7 svn compile on ubuntu 10.04 lucid 64 bits
Reporter: pobsteta | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-64 |
I use this command to compile grass 7 svn on my ubuntu :
CFLAGS="-march=native-g -Wall" ./configure --enable-debug --enable-64bit
--with-libs=/usr/lib64 --with-cxx --with-readline --with-freetype=yes
--with-freetype-includes="/usr/include/freetype2/" --enable-largefile=yes
--with-proj-share=/usr/local/share/proj/ --with-geos=/usr/local/bin/geos-
config --with-cairo --with-tcltk-includes="/usr/include/tcl8.4/" --with-
wxwidgets=yes --with-postgres=yes --with-postgres-
libs=/usr/include/postgresql/libpq --with-postgres-
includes=/usr/include/postgresql --with-sqlite=yes --with-python=yes
--with-opengl-libs=/usr/include/GL --with-ffmpeg=yes --with-ffmpeg-
includes="/usr/include/libavcodec /usr/include/libavformat
/usr/include/libswscale" --with-nls --with-blas=yes --with-lapack=yes
the compile index no errors, make -j8 and make install
grass70 works fine but the view3D crash ? NVIZ works fine with tcl/tk.
[[Image(/home/pascal/Bureau/Capture-Terminal.png)]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126&gt;
      Cpu: x86-64 |
Comment(by nikos):
May I suggest to change the summary to clearly refer to the "view-3D"
crashing?
Nikos
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:1&gt;
#1126: 3D view crashing
Component: wxGUI | Version: svn-trunk
Keywords: wxNviz | Platform: Linux
      Cpu: x86-64 |
Changes (by martinl):
  * keywords: => wxNviz
  * component: Compiling => wxGUI
Comment:
Please try out fresh SVN. The error occurs when starting 3D view mode in
wxGUI?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:2&gt;
      Cpu: x86-64 |
Comment(by nikos):
Replying to [comment:2 martinl]:
wxGUI?
Works fine here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:3&gt;
Keywords: wxNviz | Platform: MacOSX
      Cpu: x86-64 |
Changes (by helena):
  * platform: Linux => MacOSX
Comment:
On mac, in today's (Aug 16) update it crashes wxGUI when I have a raster
(elevation) and a vector (roadsmajor) in map layer list and I switch to 3D
view. It does not crash when there is only raster elevation. Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:4&gt;
#1126: 3D view crashing when started with vector data
      Cpu: OSX/Intel |
  * cpu: x86-64 => OSX/Intel
Comment:
More details about this for trunk compiled March 26, 2011:
entire wxGUI crashes after adding vector points or lines, it gives the
following error when trying to switch to 3D view
with both elevation and vector layer selected (using nc_spm data set, I
had elevation and point firestations
in map layers list, but it gives the error for line vector busroutes as
well)
(Traceback - no module named adw.advancedsplash)
v.info <t> is not a valid flag
is it trying to run v.info -t?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:5&gt;
      Cpu: OSX/Intel |
Comment(by hamish):
Replying to [comment:5 helena]:
> but it gives the error for line vector busroutes as well)
v.info printing flags were changed in trunk. I quite disagree with that
change and would like to revert it before too long, as it introduces a
contextual meaning extra level of abstraction to learn/deal with, makes
life harder for command line users while offering dubious advantage to the
module's GUI users, fixes what wasn't broken in the first place, and makes
the module inconsistent with other core module usage (which IMNSHO should
not be moved away from flags either, and certainly not without widespread
positive feedback/consensus).
best,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:6&gt;
      Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:6 hamish]:
I was just waiting for some discussion, more opinions. I received only
yours negative one and nothing more. So I will revert changes `v.info` at
this point.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:7&gt;
      Cpu: OSX/Intel |
> to learn/deal with, makes life harder for command line users while
offering dubious advantage to the module's GUI users, fixes what wasn't
broken in the first place, and makes the module
btw, here should be used `grass.vector_topo_info()`
inconsistent with other core module usage (which IMNSHO should not be
In other words without any feedback (except yours negative), doesn't
matter if positive.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:8&gt;
Reporter: pobsteta | Owner: martinl
     Type: defect | Status: assigned
      Cpu: OSX/Intel |
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Comment:
Replying to [comment:8 martinl]:
fixed in r45779
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:9&gt;
      Cpu: OSX/Intel |
Replying to [comment:4 helena]:
still with current trunk?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:10&gt;
      Cpu: OSX/Intel |
Comment(by helena):
it works now - if I include grass6 vector data it suggests to rebuild
topology and after rebuilding, I can switch to 3D without trouble. I
think that this can be closed,
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxNviz
  Platform: MacOSX | Cpu: OSX/Intel
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:12&gt;
