[GRASS-dev] [GRASS GIS] #1165: wingrass: cs2cs fails from the msys command line
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Projections/Datums | Version: svn-develbranch6
Keywords: cs2cs, wingrass | Platform: MSWindows XP
      Cpu: x86-64 |
while testing r.in.wms in 6.5svn in WinGrass I'm finding that a simple
cs2cs call fails on the Msys command line. (actually happens in r.tileset)
perhaps it's not finding the "/usr/share/proj/" support files (however
that's registered in the Windows build), although `cs2cs -ld` et al. seem
to work ok.
GRASS 6.5> cs2cs +proj=longlat +to +proj=longlat
Using from definition: proj=longlat
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>:
projection initialization failure
cause: Unknown error
program abnormally terminated
GRASS 6.5> echo $?
3
the above ''should'' result in a blank line awaiting coord input.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1165 hamish]:
>the above should result in a blank line awaiting coord input.
I've tested this in the WinGrass64-release-installer, there is a blank
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
Even after applying Helmut's GDAL_DATA path fix (r43520) to the
destination files by hand, this still fails for me in 6.5svn on XP in the
same way, both Msys (etc/Init.sh) and DOS-box (grass65svn.bat).
I don't think it will help here, but should that "set GDAL_DATA=" also be
added to mswindows/osgeo4w/ini.bat.tmpl as well?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:2&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:2 hamish]:
be added to mswindows/osgeo4w/ini.bat.tmpl as well?
> thanks,
> Hamish
Hi Hamish,
I think the GDAL_DATA variable is needed for the gdal stuff.
I've studied a little bit the proj4- and cs2cs-manpages and faq:
http://trac.osgeo.org/proj/wiki/man_cs2cs
http://trac.osgeo.org/proj/wiki/man_proj
from there I've found:
The environment parameter
        PROJ_LIB establishes the default directory for a
        file reference without an absolute path. This
        is also used for supporting files like datum
        shift files.
http://trac.osgeo.org/proj/wiki/FAQ#HowdoIbuildconfigurePROJ.4tosupportdatumshifting
A default build and install on Unix will normally build knowledge of the
directory where the grid shift files are installed into the PROJ.4 library
(usually /usr/local/share/proj). On Windows the library is normally built
thinking that C:\PROJ\NAD is the installed directory for the grid shift
files. If the built in concept of the PROJ.4 data directory is incorrect,
the PROJ_LIB environment can be defined with the correct directory.
so if I'm correct there are following variables that have to be set in
windows:
GRASS_PROJSHARE => needed by grass
GDAL_DATA => needed by the gdal-stuff
PROJ_LIB => needed by the proj4/cs2cs-stuff
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:3&gt;
      Cpu: x86-64 |
Comment(by hellik):
> thanks,
> Hamish
try r43542 in the next nightly WinGrass65-build.
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:4&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 hellik]:
> > thanks,
> > Hamish
> best regards
> Helmut
AFAICT this fix above should help.
but there seems a very interesting issue with osgeo-msys-commandline.
I've tried following in the osgeo4w-stack and examples from
http://trac.osgeo.org/proj/wiki/GenParms, but not in the modified
WinGrass65-install.
(1) open OSGeo4W Shell (which is a windows-command-line with all osgeo4w-
utilities):
C:\>echo %PROJ_LIB%
C:\OSGeo4W\share\proj
C:\>cs2cs +proj=latlong +datum=WGS84 +to +proj=latlong +datum=WGS84
+pm=madrid
0 0
3d41'16.58"E 0dN 0.000
all works fine, but
(2) open osgeo4w-msys-shell
syringia@NADA ~
$ echo $PROJ_LIB
syringia@NADA ~
$ cs2cs +proj=latlong +datum=WGS84 +to +proj=latlong +datum=WGS84
+pm=madrid
0 0
nothing happens, no computations of the new coordinates, a blank line is
waiting (I've waited about 10 minutes, but nothing happend)
so maybe there are underlying problems of proj4/cs2cs in an (osgeo4w-
inherited) msys-environment?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:5&gt;
      Cpu: x86-64 |
Comment(by hellik):
this should be edited as:
utilities):
C:\>echo %PROJ_LIB%
+pm=madrid
> 0 0
all works fine, '''but'''
syringia@NADA ~
>$ echo $PROJ_LIB
syringia@NADA ~
+pm=madrid
0 0
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:6&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:6 hellik]:
osgeo4w-utilities):
> C:\>echo %PROJ_LIB%
+pm=madrid
> > 0 0
> syringia@NADA ~
> >$ echo $PROJ_LIB
> syringia@NADA ~
+pm=madrid
> 0 0
> Helmut
AFAICT this issue above is inherited by WinGrass-installer
(1) trying above example in a patched WinGrass65-installer in ''GRASS
6.5.SVN with MSYS'', that means in the delivered msys-command-line,
nothing happens with cs2cs
(2) the patched WinGrass65 started in text-mode (in a windows-command-
line), the cs2cs-example works like a charm.
so maybe a strong argument to leave msys behind in WinGrass64/65 and
deliver a shell-environment in a windows-commandline, as actuall
WinGrass70 does?
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:7&gt;
      Cpu: x86-64 |
Comment(by hamish):
yes, setting PROJ_LIB in the startup scripts helps get cs2cs running. I
get stuck in stdin-land when running from the MSys-rxvt window just like
you, but `'echo "10 10" | cs2cs'` style works ok, so scripts should be ok
as well and that only an annoyance. (I would say these things confirm our
move away from msys's rxvt, but are not so strong to force us to take
drastic action to abandon it for 6.x just yet)
From the DOS box do you have to do F6, ^Z or so to break out of cs2cs? (I
didn't test that yet)
I assume your GDAL_DATA fix is good as well for end-user systems without
C:\OSGeo4W existing, but I haven't tested.
FWIW, there is also $GISBASE/etc/nad/, but I think we need the full set of
PROJ_LIB files that were present with it when proj4 was built. The
duplication shouldn't be more than a few megabytes.
thanks for the detective work,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:8&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:8 hamish]:
(I didn't test that yet)
yes.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:9&gt;
      Cpu: x86-64 |
Comment(by hamish):
merged r43520 and r43542 from devbr6 into relbr64 and trunk with r43602
and r43603.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: cs2cs, wingrass
  Platform: MSWindows XP | Cpu: x86-64
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
I don't consider cs2cs in msys not releasing stdin to be a major bug, or
at least one we can do much about, so closing the report as the main
problem is now solved and committed.
thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:11&gt;
Comment(by glynn):
osgeo4w-utilities):
+pm=madrid
> > 0 0
> syringia@NADA ~
+pm=madrid
> 0 0
This is really a problem with the Windows rxvt port (the "MSys terminal").
According to MSVCRT's isatty() function, a Windows console is a tty, while
rxvt isn't. stdin and stdout are line-buffered if it is associated with a
tty and fully-buffered otherwise. As rxvt isn't a tty, stdout is fully-
buffered, so you won't see any output from cs2cs until it either writes a
buffer's-worth of data or it terminates (i.e. when you press Ctrl-D).
The solution is not to use rxvt. The MSys project has basically disowned
it because of issues like this. Just run sh.exe in a Windows console.
FWIW, my "MSys" icon runs a batch file which sets PATH then executes:
start C:\msys\1.0\bin\sh.exe --login -i
Apart from the issue with rxvt not being a tty, it doesn't with the
pdcurses implementation which WinGRASS should be using. Unix curses
libraries are designed for traditional ttys, where cursor positioning,
colours, etc are selected using escape sequences, which don't work with
the Windows console. pdcurses uses the Windows console API
([http://msdn.microsoft.com/en-us/library/ms687404(v=VS.85).aspx
WriteConsoleOutput] etc), and won't work with rxvt.
Oh; and rxvt is rather prone to crashing if you try to paste into it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:12&gt;
