[GRASS-dev] [GRASS GIS] #1245: v.db.connect parsing
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: v.db.connect, scripts | Platform: All
      Cpu: All |
just a placeholder bug report for the records; as reported on the mailing
list.
sqlite+v.in.ogr adds a table name to the table number reported by
v.db.connect -p,-g as "number/name". So if parsing for the table number we
need to use the -l flag as well to suppress the name.
the following shell scripts are affected, need to check the python
scripts/lib for this too.
v.colors (fixed)
d.vect.thematic
v.db.addcol
v.db.addtable
v.db.dropcol
v.db.droptable
v.db.join
v.db.renamecol
v.db.update
v.dissolve
v.out.gpsbabel
v.rast.stats
v.report
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245&gt;
Reporter: hamish | Owner: hamish
     Type: defect | Status: assigned
      Cpu: All |
Changes (by hamish):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => hamish
  * status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:1&gt;
      Cpu: All |
Description changed by hamish:
Old description:
list.
we need to use the -l flag as well to suppress the name.
v.colors (fixed)
d.vect.thematic
v.db.addcol
v.db.addtable
v.db.dropcol
v.db.droptable
v.db.join
v.db.renamecol
v.db.update
v.dissolve
v.out.gpsbabel
v.rast.stats
v.report
Hamish
New description:
list.
v.colors (fixed)
d.vect.thematic
v.db.addcol
v.db.addtable
v.db.dropcol
v.db.droptable
v.db.join
v.db.renamecol
v.db.update
v.dissolve
v.out.gpsbabel
v.rast.stats
v.report
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:2&gt;
      Cpu: All |
Comment(by hamish):
python scripts to check:
lib/python/vector.py
v.db.addtable
v.db.droptable
v.db.reconnect.all
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:3&gt;
      Cpu: All |
Comment(by hamish):
all the python in trunk is ok
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:4&gt;
      Cpu: All |
Comment(by hamish):
6.5svn scripts updated in r44641.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:5&gt;
      Cpu: All |
Comment(by neteler):
Hamish, what about the 6.4 backport?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1245#comment:6&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:6 neteler]:
as it was not a simple incisive change, before backporting I thought to
leave it in 6.5svn for a while in case there were any typos.
aka I haven't tested the changes to see if they still work.
other than that, no reason not to backport. (not being lazy with
backports; I try not to backport anything I haven't tested. so just being
lazy with testing :slight_smile:
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.db.connect, scripts
  Platform: All | Cpu: All
  * status: assigned => closed
  * resolution: => fixed
Comment:
backported to relbr64 in r45260.
possibly broken (poorly tested) is less bad than known broken (sqlite ops
in 6.4.0).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1245#comment:8&gt;
