[GRASS-dev] [GRASS GIS] #1353: ./configure with ffmpeg x86_64 - problem, with workaround
Reporter: geep999 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: Linux
      Cpu: x86-64 |
I have a bug and workaround for grass 6.4.1 ./configure with ffmpeg on
Slackware 13.37 x86_64
./configure \
--with-ffmpeg \
--with-ffmpeg-includes="/usr/include/libpostproc /usr/include/libswscale
/usr/include/libavcodec \
/usr/include/libavdevice /usr/include/libavfilter /usr/include/libavformat
/usr/include/libavutil" \
--with-ffmpeg-libs="/usr/lib64"
I get error messages like:
checking whether to use FFMPEG...
yes
checking for location of FFMPEG includes... /usr/include/libpostproc
/usr/include/libswscale /usr/include/libavcodec
/usr/include/libavformat /usr/include/libavutil
checking for avcodec.h... yes
checking for avformat.h... yes
checking for swscale.h... yes
checking for location of FFMPEG library... /usr/lib64
checking for av_free in -lavutil... yes
checking for avcodec_init in -lavcodec... yes
checking for av_set_parameters in -lavformat... no
configure: error: *** Unable to locate FFMPEG library.
This happens because ./configure is looking for:
/usr/lib64/libavcodec.so /usr/lib64/libavformat.so /usr/lib64/libavutil.so
But on my 64bit Slackware 13.37 they are installed in:
/usr/lib64/libavcodec64.so /usr/lib64/libavformat64.so
/usr/lib64/libavutil64.so
Making soft links cures the problem, but perhaps ./configure could be
upgraded.
cd /usr/lib64
ln -s libavformat64.so libavformat.so
ln -s libavcodec64.so libavcodec.so
ln -s libavutil64.so libavutil.so
I am not sure yet if I should also have created soft links for:
'''libswscale64.so libpostproc64.so libavdevice64.so libavfilter64.so'''
but they are not needed in order to get ./configure to run.
[[BR]]
Keep up the good work.
[[BR]]
[[BR]]
Peter
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1353 geep999]:
upgraded.
What does:
pkg-config --libs libavcodec
say?
If it points to the 64-bit libraries, we could try that. OTOH, if the
64-bit version is a separate package (from pkg-config's perspective), that
doesn't help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:1&gt;
      Cpu: x86-64 |
Comment(by geep999):
-lavcodec64
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:2&gt;
      Cpu: x86-64 |
Replying to [comment:1 glynn]:
upgraded.
> What does:
> say?
doesn't help.
-lavcodec64
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:3&gt;
Priority: normal | Milestone: 6.4.4
Component: Compiling | Version: 6.4.1 RCs
Keywords: ffmpeg | Platform: Linux
      Cpu: x86-64 |
Changes (by martinl):
  * keywords: => ffmpeg
  * component: Default => Compiling
  * milestone: => 6.4.4
Comment:
Could be related to (1). What version of FFMPEG are you using?
I have updated OGSF lib for new FFMPEG API in r53854. We should probably
support also the old FFMPEG's API.
(1) https://ffmpeg.org/trac/ffmpeg/ticket/1805
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:4&gt;
      Cpu: x86-64 |
Comment(by hamish):
see also #303 and #1423
Ticket URL: <https://trac.osgeo.org/grass/ticket/1353#comment:5&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 6.4.3
Resolution: fixed | Keywords: ffmpeg
  Platform: Linux | Cpu: x86-64
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
  * milestone: 6.4.4 => 6.4.3
Comment:
hopefully fixed in relbr64 with r56737. see #1423 for details.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1353#comment:6&gt;
