#1397: Lat/lon compatibility for r.water.outlet
Reporter: awickert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
Adding the attached line to r.water.outlet allows it to work across the
180 meridian in lat/lon coordinate systems.
I believe that the GRASS command G_adjust_east_longitude() is flagged to
work only in lat/lon coordinate systems, so there should not be backwards-
compatibility issues, but I haven't tested it with a projected coordinate
system.
It might be good as well to change to documentation to reflect that the
Northing and Easting can also be Latitude and Longitude.
Priority: major | Milestone: 6.4.2
Keywords: | Platform: All
Cpu: x86-64 |
Changes (by awickert):
* priority: normal => major
* platform: Linux => All
Comment:
Just got an email from someone else having problems with this, so I
increased the priority and the affected OS (it should be a totally cross-
platform problem since it is a computational issue). This is really just
an issue of copying and pasting one line of code, so it should be a simple
fix.
Keywords: r.water.outlet | Platform: All
Cpu: x86-64 |
Comment(by awickert):
Yes - looks like you are correct and that I misread when I used
G_adjust_east_longitude and thought it performed the check; I really
wanted G_adjust_easting that wraps G_adjust_east_longitude in the lat/lon
projection check.
Priority: major | Milestone: 6.4.4
Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:4 awickert]:
projection check.
> Thanks for looking into this!
Any reasons for not applying the proposed patch (but using
G_adjust_easting instead of G_adjust_east_longitude) ?
Priority: major | Milestone: 6.4.5
Cpu: x86-64 |
* milestone: 6.4.4 => 6.4.5
Comment:
Replying to [comment:6 mlennert]:
projection check.
> Moritz
In my case, I'm not a GRASS-dev, so write access was what prevented me
from doing this! I have now downloaded GRASS 6.4.5svn to incorporate all
updates to date and have applied and checked this change. I am now working
to incorporate it into GRASS 7.1.0svn and will open a separate ticket on
that once I have finished.
Thanks in advance to whomever looks into (and hopefully accepts!) this
fix. Files attached.
