#1399: v.surf.rst fills up all available hard drive space when region is not set
Reporter: Stephan66 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: Linux
Cpu: Unspecified |
When v.surf.rst is called and no region has been set (i.e. using
g.region), it will fill up all available storage space in my grassdata
directory (~ 130 GB in just a few minutes....).
System: openSuSE 11.4 (x86_64)
Packages installed from OBS:
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: 6.4.1 RCs
Keywords: v.surf.rst | Platform: Linux
Cpu: Unspecified |
Changes (by martinl):
Cpu: Unspecified |
Comment(by marisn):
There's always a region. Please run g.region -p and report results here.
Cpu: Unspecified |
Type: defect | Status: closed
Resolution: invalid | Keywords: v.surf.rst
Platform: Linux | Cpu: Unspecified
Changes (by marisn):
* status: new => closed
* resolution: => invalid
Comment:
I'm sorry. v.surf.rst just does what You have ordered. It would create a
raster with 73665360000 cells, that would take approx. 550 Gb of RAM/disk
(rough calculation without taking into account any compression or
overhead). Next time just check Your region settings before performing any
analysis.
