[GRASS-dev] [GRASS GIS] #1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-trunk
Keywords: hard copy map utility, ps.map | Platform: Unspecified
      Cpu: Unspecified |
Comment(by cmbarton):
I just committed the fixes I've been working on the past several days, but
also incorporated all your changes prior to committing.
r48226
This seems to fix all prior problems except for a very weird one that I
hope you have some insight into. For map info, the background and border
shows up fine if the map info text is positioned in the top half of a
page. If it is positioned in the bottom half of the page, the text
displays fine, but the background and border disappear. Even odder, this
behavior does NOT happen with the text objects.
If this tests out for other systems, maybe it can be backported, though
the map info behavior is still not quite right.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:20&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:20 cmbarton]:
> I hope you have some insight into. For map info, the background and
> border shows up fine if the map info text is positioned in the top
> half of a page. If it is positioned in the bottom half of the page,
> the text displays fine, but the background and border disappear.
> Even odder, this behavior does NOT happen with the text objects.
that's a known problem, see #192 comment 5.
  https://trac.osgeo.org/grass/ticket/192#comment:5
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:21&gt;
      Cpu: Unspecified |
Ah. Glad I didn't spend a lot of time trying to fix this particular issue
:wink:
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:22&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Michael, can we close this ticket or are there any issues I forgot? All
recent changes are backported.
Anna
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:23&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: hard copy map utility, ps.map
  Platform: Unspecified | Cpu: Unspecified
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
Yes, close.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:24&gt;
