#1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-trunk
Keywords: hard copy map utility, ps.map | Platform: Unspecified
Cpu: Unspecified |
Trying to add text to an output cartography window in the hard copy map
utility raises the following error:
File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/etc/gui/wxpython/gui_modules/psmap_dialogs.py",
line 1677, in OnOK
ok = self.OnApply(event)
line 1670, in OnApply
self.parent.DialogDataChanged(id = self.id)
darwin10.8.0/etc/gui/wxpython/gui_modules/psmap.py", line
763, in DialogDataChanged
extent = self.getTextExtent(textDict =
self.instruction[id].GetInstruction())
681, in getTextExtent
dc.SetFont(wx.FontFromNativeInfoString(textDict['font'] + "
" + fontsize))
File "/Users/Shared/grass_dev/grass70_dev/macosx/dist/GRAS
S-7.0.app/Contents/MacOS/etc/python/wx/_gdi.py", line 2309,
in FontFromNativeInfoString
val = _gdi_.new_FontFromNativeInfoString(*args, **kwargs)
wx._core
Cpu: Unspecified |
Comment(by cmbarton):
I see now why a custom font dialog is being used--to match the font
commands of ps.map. I've managed to fix the original problem in this
report, but now there is a further related problem.
ps.map seems to use special font names like "Times-Roman" that are
perfectly understandable but which do not match the relevant font name in
wxPython. These are listed in the ps.map manual and hard coded into
psmap.py. For example, the font "Times-Roman" is one of the fonts listed
in the ps.map manual but this is not the way this font face is referred to
in wxPython. On the Mac, this font is called "Times New Roman" (with the
word "New" and lacking hyphens).
If we are supposed to use real font names (i.e., those appropriate for a
given platform) and those in the manual are just generic suggestions, they
we can use wx.FontDialog with some translation of font attributes like
color and pointsize. But if the font names listed in the ps.map manual are
the only forms that are recognized, we need to somehow map between these
hard coded font names in the ps.map module and their equivalents in
wxPython across all 3 major platforms.
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:2 cmbarton]:
perfectly
wxPython.
> These are listed in the ps.map manual and hard coded into psmap.py.
AFAIU these are hardcoded in your printer / the PostScript definition,
which is why they differ from whatever fonts are installed in your system.
The two sets are completely independent, any overlap in names is just
coincidental.
ps.map man page:
font font name
The name of the PostScript font. Fonts present in all Post-
Script implementations are: ...
depending on your make/model of postscript printer you may have access to
more options...
embedding a truetype font from the OS into a PDF is another matter, I'm
not sure if that is possible given our ps2pdf distilling method.
Cpu: Unspecified |
OK. That means we need to use the font names in the manual or find a
Python command that will reveal the names of any installed PS fonts.
The code that is breaking here is trying to use the PS font name as a
TrueType font to estimate the size of the text box for placement in the
graphical page representation. This won't work. It only seemed to work
because of the fact that some TrueType fonts and some PS fonts have the
same name.
So we need a different way to estimate the size of the text box.
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:4 cmbarton]:
> as a TrueType font to estimate the size of the text box for placement
> in the graphical page representation. This won't work. It only seemed
> to work because of the fact that some TrueType fonts and some PS fonts
> have the same name.
hmm, well we know exactly how tall the text will be (10/72" for 10pt,
12/72" for 12pt, ..) but not how wide for proportionally widthed fonts. We
can probably figure out the aspect ratio for a fixed width font like
Courier and just use that knowing it won't be any wider. (???)
Cpu: Unspecified |
OK. I think I've fixed this. Please test. It is r48193 in trunk only right
now. Especially check to make sure that Times displays correctly. It works
on my Mac but I'm not positive that it works on other systems (hopefully
so).
There is one issue remaining. I've fixed it so that it recognizes
multiline text. This works for the box outline drawn in the layout window
and in the preview too. But the layout window also shows the text itself
and not just the text box outline. The text being printed to the layout
window somehow is not getting line breaks, even though they seem to be in
the original text string stored for display.
The relevant line here is 1558 of psmap.py if anyone wants to see why the
layout text is not breaking correctly.
Cpu: Unspecified |
Comment(by hamish):
"cartographic composer" ??
as for newlines being respected I think that's dependent on the various
commenting instructions, some want '\n', some can use real newlines, not
sure, would need to go through and see what's implemented and what works
which way before coming up with a general solution.
Cpu: Unspecified |
Comment(by glynn):
!PostScript fonts are installed on the printer, not the computer. There is
no guarantee that it's possible to read information from the printer
(there might not even /be/ a printer; you might just be generating a
file).
!TrueType font to estimate the size of the text box for placement in the
The only way to do this is to have AFM/PFM (font metrics) files for the
fonts in question, and to use the data which they contain. This is made
more complex by the fact that !PostScript uses kerning by default, so you
can't just sum the widths of the individual characters.
Cpu: Unspecified |
The main question is how close does this need to be for text placement.
Also, we don't want the module to raise an error when it's only trying to
figure out the size of a layout box.
The way I've got it set up now is that it will try to use typefaces with
names Times, Helvetica, or Courier, depending on which one of these ps.map
fonts is picked. If it can't find one, it will revert to the "default"
font family for the system. This can be fine tuned.
Perhaps it would be better just to pick the corresponding font family from
wxPython (e.g., wx.FONTFAMILY_SWISS for Helvetica) and not worry about
finding a particular typeface.
Cpu: Unspecified |
I've been trying to work out the issues with management of color for text
objects (including the 'map info' text object). The behavior is as
follows:
1) If border or background color is enabled but a color is not explicitly
set, it raises the error of 'ps.map exited with a 1' (NB: this is a really
useless error).
2) If a background color or border color is set for a text object it seems
to show up in the preview and final output pdf.
3) If a background color or border color is set of a map info object, it
may or may not show up in preview and output. I've yet to come up with a
sequence of steps that make this happen or not.
There are 2 sets of dictionaries of settings maintained by the ps modules.
1 set is a dictionary for each class of function (text, legend, map info,
etc); the other is a single large dictionaries of "instructions" that are
used to build a ps.map script. AFAICT, the problems in # 1-3 above are
probably a result of incomplete or incorrect updating between these two
dictionary sets, and possibly between the dictionaries of settings and the
actual interface controls.
Nothing is standing out to me that is incorrect so far. So I'm recording
this in case another set of eyes wants to take a look sometime. I'm not
sure whether it is worth it yet to backport the changes to the GRASS 6
branches I've done until these other issues are solved or not. It is
working better than it was, but there are still these inconsistencies.
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:11 cmbarton]:
Thanks for the patch, I changed a little (r48220) the makePSFont method,
it was not working for me.
Cpu: Unspecified |
Replying to [comment:12 cmbarton]:
explicitly set, it raises the error of 'ps.map exited with a 1' (NB: this
is a really useless error).
I cannot reproduce this error, do you talk about map info or text?
seems to show up in the preview and final output pdf.
I fixed the background color of text in draft mode. I tried to draw the
text border in draft mode but it kept disappearing. I couldn't find the
problem so I left it without it. Maybe a tooltip or a static label could
inform user that not all features are visible in draft mode (like text
highlight).
The color in draft mode is always blue and it has no other meaning. In
preview mapinfo background color depends on its position, see #192
Cpu: Unspecified |
Replying to [comment:14 annakrat]:
highlight).
it may or may not show up in preview and output. I've yet to come up with
a sequence of steps that make this happen or not.
I'm close to fixing this, but have not yet committed those changes because
they still have a few weird inconsistencies that have to do with updating
after a drag event. I'll see how your changes mesh with mine. It's a
pretty busy day today so I might not get to it until the weekend.
Cpu: Unspecified |
Replying to [comment:18 cmbarton]:
because they still have a few weird inconsistencies that have to do with
updating after a drag event. I'll see how your changes mesh with mine.
It's a pretty busy day today so I might not get to it until the weekend.
I appreciate your help however it would be more efficient if I try to fix
the problems first because I understand the code better (as the author).
On the other hand it's always better if someone else can understand and
maintain the code.
Maybe you could summarize the problems and inconsistencies you encountered
because I'm getting quite confused. Some problems may be platform
specific, some inconsistencies in wx.psmap have their origin in ps.map
module and I can explain them more.
