[GRASS-dev] [GRASS GIS] #1470: v.out.ascii with sql where option exports only centroids and not areas
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
It's not possible to export areas selected by SQL WHERE clause.
Example from NC data set. Let's export only lake with CAT=5109:
v.out.ascii input=lakes@PERMANENT layer=1 output=vbuffer_fail_on_area3
where=cat=5109 format=standard
Output vector part:
C 1 1
  627457.82440791 231495.92575519
  1 5109
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470&gt;
Priority: normal | Milestone: 6.4.3
Keywords: v.out.ascii | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: => v.out.ascii
  * milestone: => 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:1&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [ticket:1470 marisn]:
> Output vector part:
> C 1 1
> 1 5109
This is logicial in the sens that only the centroid has a cat=5109. No
boundary has this cat. So this would mean implementing a specific
algorithm to check which boundary needs to be exported together with this
centroid.
As a workaround: v.extract and then v.out.ascii. Maybe this can be coded
in a script ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:2&gt;
      Cpu: Unspecified |
Old description:
Output vector part:
C 1 1
1 5109
New description:
{{{ood
Output vector part:
C 1 1
  1 5109
Comment(by martinl):
Replying to [comment:2 mlennert]:
centroid.
Basically it could be possible. Currently `v.out.ascii` opens vector map
on level 1 (without topology). This would require level 2 (topology). I
can imagine special flag which writes out also areas (boundaries and
centroids), not only centroids. The problem is that boundaries of adjacent
areas will printed twice. I am not sure whether it's a good idea to extend
functionality of this module in this direction. Any opinion?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:3&gt;
      Cpu: Unspecified |
Description changed by martinl:
Old description:
{{{ood
Output vector part:
C 1 1
1 5109
New description:
Output vector part:
C 1 1
  1 5109
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:4&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:3 martinl]:
centroid.
There is enough code in GRASS (other modules, libs) that takes care of
such cases, boundaries would not be written twice. Basically a boundary
would be written out if the centroid of any of its two areas has a cat
value which is in the list. I would like to see that option/functionality
in `v.out.ascii` because most of the time the vector objects a user works
with are points, lines, areas. Modules/libs then take care of appropriate
handling of boundaries and centroids.
my2c
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:5&gt;
      Cpu: Unspecified |
Replying to [comment:5 mmetz]:
right, please try out r48886 and r48887 (trunk).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:6&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:6 martinl]:
I have modified r48886 to avoid segfaults and r48887 to open vectors with
topology only when needed (partially restoring original behaviour to
support fast export of massive point vectors).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:7&gt;
      Cpu: Unspecified |
Replying to [comment:7 mmetz]:
with topology only when
ops, thanks. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:8&gt;
      Cpu: Unspecified |
Replying to [comment:8 martinl]:
small fix in r48894
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:9&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:9 martinl]:
> small fix in r48894
ops, thanks;) Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:10&gt;
Priority: blocker | Milestone: 6.4.3
      Cpu: Unspecified |
  * priority: normal => blocker
Comment:
Backported to devbr6 for testing (r48914)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:11&gt;
Reporter: marisn | Owner: martinl
     Type: defect | Status: assigned
      Cpu: Unspecified |
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Comment:
backported also to relbr64 (-> GRASS 6.4.3), testing welcomed (r50981)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.out.ascii
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: assigned => closed
  * resolution: => fixed
Comment:
The export is now:
v.out.ascii input=lakes output=vbuffer_area where=cat=5109 format=standard
grep 'B \|C ' vbuffer_area
B 93
B 152
B 162
B 3
B 3
C 1 1
Reimport:
v.in.ascii vbuffer_area out=myarea format=standard
Building topology for vector map <myarea>...
Registering primitives...
6 primitives registered
414 vertices registered
Building areas...
  100%
1 areas built
1 isles built
Attaching islands...
  100%
Attaching centroids...
  100%
Number of nodes: 6
Number of primitives: 6
Number of points: 0
Number of lines: 0
Number of boundaries: 5
Number of centroids: 1
Number of areas: 1
Number of isles: 1
v.in.ascii complete.
Looks correct. Closing since it appears to be fixed. Reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:13&gt;
