#1517: 'DateTime' not handled by v.in.ogr
Reporter: grasslandtom | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Database | Version: 6.4.2 RCs
Keywords: v.in.ogr, DateTime, TIMESTAMP | Platform: Unspecified
Cpu: Unspecified |
steps to reproduce:
_ create a table in PostGIS-database 'test':
create table test (id INT, datetime TIMESTAMP);
SELECT addgeometrycolumn('test', 'the_geom', 4030, 'POINT', 2);
insert into test values (1, '2001-01-01 00:12:00', st_setsrid(ST_point(12,
50), 4030));
_ import in GRASS:
v.in.ogr dsn='PG:dbname=test' out=test layer='test(the_geom)'
location=new_test
This raises the error
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected NAME processing 'datetime'
in statement:
create table test (cat integer, datetime datetime, id integer)
Error in db_execute_immediate()
When the location is connected to PostGIS:
_ import in GRASS
v.in.ogr -o dsn='PG:dbname=test' out=test_out layer='test(the_geom)'
raises the error
DBMI-Postgres driver error:
Cannot execute:
create table test_out (cat integer, datetime datetime, id integer)
FEHLER: Typ »datetime« existiert nicht
LINE 1: create table test_out (cat integer, datetime datetime, id in...
(Sorry for the German error message. This one seems to come from the
PostgreSQL Server which was running before I set the respective
environment variables)
When the location is connected to SQLite, the import works without a
warning respective to DateTime but
db.columns test_out
raises
WARNING: SQLite driver: unable to parse decltype: datetime
WARNING: SQLite driver: column 'datetime', SQLite type 3 is not supported
cat
id
Note that
ogrinfo 'PG:dbname=test' 'test(the_geom)'
gives in the last lines
datetime: DateTime (0.0)
OGRFeature(test(the_geom)):0
datetime (DateTime) = 2001/01/01 0:12:00
id (Integer) = 1
POINT (12 50)
Thus, DateTime seems to exist in OGR. Though the SQL data type is
TIMESTAMP.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1517>
