[GRASS-dev] [GRASS GIS] #1536: add EPSG:900913 to location wizard
Reporter: timmie | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Projections/Datums | Version: 6.4.2 RCs
Keywords: | Platform: MSWindows XP
      Cpu: Unspecified |
The Google Mercator Projection sometimes referred to as ESRI-EPSG code
900913 while it does not have an official code?
http://spatialreference.org/ref/sr-org/6/
Even in the GRASS docs, 900913 is used:
http://grass.fbk.eu/gdp/html_grass64/g.proj.html
In GRASS location wizard (version 6.4.2RC2) the code 900913 is not
present. But g.proj -c epsg=900913 loc=google works.
How does this fit together?
Could the code officially be added?
Thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536&gt;
Keywords: google projection, epsg | Platform: MSWindows XP
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => google projection, epsg
  * type: defect => enhancement
Comment:
after originally reacting with horror, AFAIU the epsg people have given up
the fight and issued the spherical mercator with wgs84's major ellipsoid
radius its own epsg code. So this will be fixed in time with a new version
of the epsg file and the only action needed is to wait. it is not
recommended to use spherical merc for real analysis, only data transfer
and matching visual cartography.
it is designed to be very fast on their servers, not to seek the ultimate
perfection in geodesy. (fair enough for their needs)
I think g.proj works but it isn't listed in the wizard as the wizard just
parses the main epsg file while g.proj uses the PROJ4 library which also
checks the esri.extra file that contains the "Chris's funny" projection.
be careful calling it the 'google' projection, their google maps slippy
tile projection is a slightly different thing again (and even more
distorted). each row of tiles has its own slightly different projection!
the two are related but get confused a lot.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1536#comment:1&gt;
Keywords: google projection, epsg | Platform: All
      Cpu: Unspecified |
Changes (by neteler):
  * platform: MSWindows XP => All
Comment:
I would note that it is not the official code:
tail -3 /usr/share/proj/esri.extra
# Chris' funny epsgish code for the google mercator
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs <>
The fact that 900913 exists is AFAIK historically: to get +nadgrids=@null
into a code. For subsequent history, see Hamish's comment above.
See also:
http://trac.osgeo.org/openlayers/wiki/SphericalMercator
"SphericalMercator and EPSG aliases
The SphericalMercator projection in OpenLayers uses code epsg:900913. When
Google started to use the SphericalMercator projection, a corresponding
EPSG
code did not yet exist, so a temporary code '900913' (notice the
resemblance
to the word 'google') was invented. Many other services, such as
OpenStreetMap,
Bing and Yahoo are now also using the same projection, but are not
necessarily
supporting the use of code EPSG:900913. Other codes, such as EPSG:3857 and
EPSG:102113 were invented. Today, there is an officially registered EPSG
code
3857 whose projection is identical to EPSG:900913.
(http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::3857)."
I would suggest to support the official code rather than the inofficial
one
which may disappear since superceeded.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536#comment:2&gt;
      Cpu: Unspecified |
Comment(by timmie):
thank you very much for your explanantion.
Is there a consensus in OSGEO apps what to use?
QGIS definately used 900913 for the Google sperical Mercator.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536#comment:3&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:3 timmie]:
I have cited the Openlayers comment, hence they consider it a
temporary and unofficial code number.
... which does not make it ufficial nor correct :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536#comment:4&gt;
      Cpu: Unspecified |
Comment(by timmie):
Should this be then brought to the attention of:
http://trac.osgeo.org/metacrs/
or
all http://wiki.osgeo.org/wiki/Project_Steering_Committees
Ticket URL: <http://trac.osgeo.org/grass/ticket/1536#comment:5&gt;
Priority: normal | Milestone: 6.5.0
      Cpu: Unspecified |
  * milestone: 6.4.2 => 6.5.0
Comment:
is the real problem that the other epsg sibling files are not considered?
Should the location wizard concatenate them all, if found?
/usr/local/share/esri, esri.extra, other.extra
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1536#comment:6&gt;
