#1570: In GRASS6.4.2RC3 with wxpython GUI the option Add raster cell numbers
doesn't work
Reporter: clerici | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: Linux
Cpu: x86-64 |
seems not to work. Clicking Apply (or OK) in the d.rast.num command panel,
nothing is displayed in the Map Display, and in the Command console
appears the message: 'd.rast.num' failed. Details: !!!
The command runs fine in tcltk GUI and in Command line mode.
doesn't work
Cpu: x86-64 |
Comment(by annakrat):
Should be fixed in r51824, r51825, r51827 (all branches). The problem is
that you must check "Constrain display resolution to computational
settings" in "Display resolution" in Map Display statusbar (now it asks
you and then it's done automaticaly) and be careful how many cells you are
displaying.
