[GRASS-dev] [GRASS GIS] #1577: r.stream.extract/r.stream.order - "calculated" mainchannel vs. "real" mainchannel
mainchannel
Reporter: hellik | Owner: grass-dev@…
Priority: minor | Milestone: 6.4.2
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, addon | Platform: MSWindows Vista
      Cpu: x86-32 |
hi,
tested with wingrass64svn, srtm v4.1 (lat/long, ETRS89-LAEA, UTM zone N33)
and a river basin in the eastern part of the
alps (if needed,a test-location is available).
there'a really nice grass-addon available (thanks to Margherita) which
calculates some
ecological relevant characteristics of river-basins:
http://trac.osgeo.org/grass/browser/grass-
addons/grass6/raster/r.basin/r.basin.py
the mainchannel of such a river basin is calculated by some calculation
steps of r.stream.extract [1]
and r.stream.order [2]
addons/grass6/raster/r.basin/r.basin.py#L261
addons/grass6/raster/r.basin/r.basin.py#L368
there seems to be sometimes a difference between the "calculated" and the
"real" (in the meaning of official hydrography,
science literature, etc.) mainchannel.
an example screenshot of river basin in the eastern part of the alps is
attached
may I cite Margherita:
1) stream extraction, by r.stream.extract. This step is dependent by the
threshold.
2) stream ordering. The Hack order assigns the value 1 to the longest
contributor, so that it actually individuates the main channel. This is
done by r.stream.order. Successively, r.basin just does a series of monkey
steps to turn the first hack order segment into vector and query the
length. When Jarek wrote r.stream.order, i asked him to add Hack order
just
for that. When i was testing it, sometimes i raised with him the problem
that you mention, and i don't remember if either he fixed it or wasn't
able
to reproduce the issue.
Said that, i would suggest to raise the issue in dev-ML, so that either
Markus Metz (from the r.stream.extract side) or Jarek (from the
r.stream.order side) could answer and likely fix the problem. I would also
suggest you to verify if the problem is due to a mistake in stream
extraction, say the individuated mainchannel is actually longer than the
other (natural) one (and this could be likely fixed by varying the
threshold) or in hack ordering assignment, which is not able to
individuate
the longest segment. Only in this second case, a bug-fix by Jarek is
needed.
any ideas how to get the calculated mainchannel matching the real
mainchannel?
I've tried a few different thresholds, but I've always get this
"mismatch".
best regards
Helmut
[1] http://trac.osgeo.org/grass/browser/grass-
addons/grass6/raster/r.stream.extract
[2] http://trac.osgeo.org/grass/browser/grass-
addons/grass6/raster/r.stream.order
Ticket URL: <http://trac.osgeo.org/grass/ticket/1577&gt;
mainchannel
      Cpu:  x86-32           |
 hi,
 calculates some
 [http://trac.osgeo.org/grass/browser/grass](http://trac.osgeo.org/grass/browser/grass)-
what does it means? Any reference? Main channel established in real network or algorithms of modeling main channel?
 attached
where it is?
Sorry. I cannot relate to this ticket, because, it is not clear what kind of issue it reports.
r.stream.order does not calculate “main channel”. It is impossible, bacuase main channel is marked according different criteria, depending on national surveys. R.stream.order in Gravielius/Hack hierarchy (Hack is used after jGrass, this name is not especially correct) calculate stream of first order as longest channel or optionally if you use SFD it can use alternatively channel draining biggest basin area. That all. if it is main or not main channel it is interpretation. Data generated by hydrological modeling are deterministic realization of clear algorithms on the specific dataset and does not reflect reality in 100%.
Hope it helps
the mentionned "real" mainchannel is the part of real Austrian river network
(i.e. listed in the annual Austrian hydrographical handbook as the river
'Isel')
attached
where it is?
it's in the ticket, see
http://trac.osgeo.org/grass/attachment/ticket/1577/mainchannel4.gif
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-GIS-1577-r-stream-extract-r-stream-order-calculated-mainchannel-vs-real-mainchannel-tp4473866p4474065.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
network (i.e. listed in the annual Austrian hydrographical handbook as the
river 'Isel')
or may have also a look in the pdf mentioned in
http://wisa.lebensministerium.at/article/archive/29373
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-GIS-1577-r-stream-extract-r-stream-order-calculated-mainchannel-vs-real-mainchannel-tp4473866p4474112.html
'Isel')
It is popular argument against algorithmic approach. Usually computer algorithms cannot reproduce arbitrary human decisions :frowning:
attached
where it is?
Helmut
Ok, this is not software issue. In attached example calculated main channel is evidently longer than real main channel so software cannot calculate it different. On my first look there are two possibilities:
- first: main channel is established according to basin area. If so try to model stream network using SFD and next Gravelius hierarchy using accumulation map as an option. Result should be correct. This is impossible using MFD approach
- second: main channel is arbitrary chosen as "central channel". No idea how to reproduce it without complex analysis of basin shape and network topology.
J.
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
'Isel')
As Jarek said, there is nothing like the one and only "real"
mainchannel because there a different definitions on how to determine
the main channel. You would need to get the definition of "real
mainchannel" out of the Austrian hydrographical handbook, maybe modify
input accumulation for r.stream extract and then use the best matching
method in r.stream.order.
Markus M
Jarek:
network
'Isel')
Markus M:
in this example it's based on hydrographical characteristics:
- the "real" mainchannel (river Isel) has an (nival)/gacial runoff regime
- the calculated mainchannel (river Schwarzach) has an nival runoff regime,
and flows into the river Isel
Jarek, Markus M, thanks a lot for the insight!
best regards
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-GIS-1577-r-stream-extract-r-stream-order-calculated-mainchannel-vs-real-mainchannel-tp4473866p4475056.html
mainchannel
Priority: minor | Milestone: 6.4.3
Keywords: r.basin, addon | Platform: MSWindows Vista
      Cpu: x86-32 |
Changes (by neteler):
  * keywords: wingrass, addon => r.basin, addon
  * milestone: 6.4.2 => 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1577#comment:1&gt;
mainchannel
      Type: enhancement | Status: closed
Resolution: wontfix | Keywords: r.basin, addon
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
  * status: new => closed
  * resolution: => wontfix
Ticket URL: <http://trac.osgeo.org/grass/ticket/1577#comment:2&gt;
