[GRASS-dev] [GRASS GIS] #1584: error in r.walk help page
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Docs | Version: unspecified
Keywords: r.walk | Platform: All
      Cpu: All |
one from Agustin:
the documentation in r.walk is wrong. It says:
"The default values for a, b, c, d are those proposed by Langmuir
(0.72, 6.0, 1.9998, -1.9998)"
and it should say:
(0.72, 6.0, -1.9998, 1.9998)"
because the point is that you go faster on gentle slopes and more
slowly on steeper slopes and those values are in m/s
The worrying question is whether these values are also wrong in the
default values of r.walk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1584&gt;
      Cpu: All |
Comment(by dkavanagh):
There is also a mistake in the Standard Directions figure in the Movement
Direction section. 90 should be immediately below x and the zero should be
removed.
Replying to [ticket:1584 hamish]:
> one from Agustin:
> and it should say:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:1&gt;
      Cpu: All |
My note applies to 6.5 and 7.0. The Langmuir correction applies to all
versions.
Replying to [comment:1 dkavanagh]:
Movement Direction section. 90 should be immediately below x and the zero
should be removed.
> > one from Agustin:
> > and it should say:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:2&gt;
      Cpu: All |
Hamish - I believe the help is correct. c and d are multiplied by the
delta, which in a downward slope will be negative. Here is an example from
the code - fcost_dtm = (double)((double)(W_dtm - my_dtm) * c);
> one from Agustin:
> and it should say:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:3&gt;
Component: Docs | Version: svn-releasebranch64
      Cpu: All |
Changes (by neteler):
  * version: unspecified => svn-releasebranch64
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:4&gt;
  Priority: major | Milestone: 7.1.0
Resolution: | Keywords: r.walk
       CPU: All | Platform: All
* milestone: 6.4.3 => 7.1.0
Comment:
Bumped for check to 7.1. In case backports down to G6.4 are needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1584#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.walk
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 neteler]:
I was looking into that recently in 7 and I think it's fine.
I backported some of the documentation in r65411.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1584#comment:6&gt;
