[GRASS-dev] [GRASS GIS] #1603: v.surf.bspline won't interplolate across meridian 0
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: unspecified
Keywords: v.surf.bspline | Platform: Unspecified
      Cpu: Unspecified |
In GRASS 6.4.3 (and probably 6.4.2), v.surf.bspline won't interpolate the
western half of a region centered on the Greenwich meridian (Longitude =
0).
This does work OK in GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603&gt;
Priority: major | Milestone: 6.4.3
      Cpu: Unspecified |
Changes (by cmbarton):
  * priority: normal => major
Comment:
Hmm. It doesn't work in GRASS 7 either. Also, points don't display across
the Greenwich meridian in GRASS 7
It worked yesterday. The only difference is that I just recompiled new
versions of both 6.4.3 and 7 today. So it must have broken since 27
February 2012. With the display problem too, this seems like something
fairly major. Can someone check to see if they get the same problems?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603#comment:1&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
I've attached a screen shot to show what I'm talking about. There are a
batch of points (actually a fully global file) and the interpolation
created by v.surf.bspline. Note that it stops at the meridian. This one
interpolated the west but not the east. There is no error. I think it may
have to do with an inability to read the points across the meridian.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603#comment:2&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 cmbarton]:
across the Greenwich meridian in GRASS 7
I can not reproduce the error. For a global dataset in latlon covering
-180,180 longitude the full region is interpolated.
Can you provide the full output of v.info of the input vector, r.info of
the output raster and g.region of the current region? Thanks!
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603#comment:3&gt;
#1603: vector points made from global raster won't display or interplolate across
meridian 0
      Cpu: Unspecified |
Markus,
I can give some more info on this. I no longer think that it is a problem
with v.surf.bspline specifically, but with how vectors (and maybe rasters)
are read in a latlon region. I'll described what I did that caused the
problem and the work around I discovered.
**THE PROBLEM**
I imported a global raster file (paleoclimate file). It's extents are from
s=90S n=90N w=0W e=0E. I used r.to.vect to create a set of points from the
center of each grid cell.
Then I created a region with extents s=24N n=90N w=85W e=35E. I wanted to
interpolate the points to a higher resolution within this smaller region.
Only the portion from 0-35E OR 0-85W was interpolated. But when I
displayed the points, only the points from 0-35E OR 0=85W were displayed.
So I think that even though I have points both east and west of
longitude=0, GRASS will only read them on one side or the other of the
central meridian.
**THE WORK AROUND**
After some experimentation, I did made a mask that matched the new region
(24-90N and 85W-35E) and use r.mapcalc to create a new raster that was
cropped to match this region. Note that there is no problem in displaying
or creating a RASTER for this region from the original one.
Then I made a new point-set from the cropped raster. THIS point-set did
display correctly in this region and DID interpolate correctly using
v.surf.bspline. Note that this new point-set is a geographic subset of the
original global point-set but it displays and is read correctly while the
portion of the global point-set that lies within the reduced region does
not.
So I think the problem is how GRASS is creating and reading the vector
points. AFAICT, the points in global set that are located geographically
in my region from 85W to 35E look exactly the same coordinate-wise as the
points created from the raster cropped to match the region. But somehow
they are different.
We need to relabel this ticket, but I'm not sure how best to label it.
Maybe you can suggest a better label. Something with a vector library or
other library perhaps? I've changed the name of the ticket.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603#comment:4&gt;
