[GRASS-dev] [GRASS GIS] #1613: r.hazard.flood.py returns a ParseError
Reporter: Ddm | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: unspecified
Keywords: r.hazard.flood.py | Platform: MSWindows 7
      Cpu: Unspecified |
I'm trying to run the r.hazard.flood.py add-on, but I'm getting the
following error message.
I'm new to GRASS so I apologise if this is an obvious user error.
Many thanks.
(Mon Mar 12 22:47:16 2012)
r.hazzard.flood.py
C:\Program Files (x86)\GRASS 6.4.2\extrabin\python.exe:
can't open file 'r.hazzard.flood.py': [Errno 2] No such file
or directory
(Mon Mar 12 22:47:17 2012) La commande s'est terminée (0 sec)
   File "C:\Program Files (x86)\GRASS
6.4.2\etc\wxpython\gui_modules\prompt.py", line 1105, in
OnKeyPressed
self.parent.RunCmd(cmd)
6.4.2\etc\wxpython\gui_modules\goutput.py", line 523, in
RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
6.4.2\etc\wxpython\gui_modules\menuform.py", line 1732, in
ParseCommand
blackList = _blackList)
6.4.2\etc\python\grass\script\task.py", line 460, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
6.4.2\Python27\lib\xml\etree\ElementTree.py", line 1283, in
XML
return parser.close()
6.4.2\Python27\lib\xml\etree\ElementTree.py", line 1636, in
close
self._raiseerror(v)
6.4.2\Python27\lib\xml\etree\ElementTree.py", line 1488, in
_raiseerror
raise err
xml.etree.ElementTree
ParseError
no element found: line 1, column 0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613&gt;
      Cpu: Unspecified |
Comment(by madi):
you are trying to run 'r.hazzard.flood.py', which is a typo. Correct is
r.hazard.flood.
Nevertheless, if i try to run r.hazzard.flood as you did, i don't get that
error message.
By the way, the module is an add-on written on linux platform, and AFAIK
not yet tested on windows. If you are willing to test it, you are very
welcome.
Could you please try to run it again. And, please, download the r51053. I
just found that the version online was not up-to-date.
madi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:1&gt;
      Cpu: Unspecified |
Comment(by Ddm):
hi,
Thanks for your help.
Actually, it is not a typo: I do have to launch "r.hazard.flood.py".
Otherwise I get the error message below. It is also hte name that appears
in my list of modules. As a matter of fact, it is the only one that has
the ".py" extension in this list.
I also updated with the latest code but I still get the same error message
(the original one I mean).
(Tue Mar 13 23:39:10 2012)
r.hazard.flood
C:\Program Files (x86)\GRASS 6.4.2\Python27\lib\site.py:158:
Warning: 'with' will become a reserved keyword in Python 2.6
'import site' failed; use -v for traceback
6.4.2\Python27\lib\linecache.py:127: Warning: 'with' will
   File "C:\Users\David\AppData\Roaming\GRASS6\addons\r.hazar
d.flood.py", line 47, in <module>
     import grass.script as grass
6.4.2\etc\python\grass\__init__.py", line 1, in <module>
     import os
6.4.2\Python27\lib\os.py", line 754
     bs = b""
SyntaxError: invalid syntax
(Tue Mar 13 23:39:10 2012) La commande s'est terminée (0 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:2&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:2 Ddm]:
yeap, the extension is required on MS Windows. Otherwise OS doesn't know
which interpreter to use.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:3&gt;
      Cpu: Unspecified |
Comment(by madi):
> hi,
message (the original one I mean).
> r.hazard.flood
> import os
> bs = b""
hi,
thanks for feedback. Actually the typo I meant is "hazzard" instead of
"hazard".
I am not able to reproduce the error because i don't have access to
windows machine. Any idea from developers is very appreciated to try to
solve this issue. Thanks for patience.
madi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:4&gt;
      Cpu: Unspecified |
Comment(by Ddm):
Ah OK... sorry for the misunderstanding. :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:5&gt;
      Cpu: Unspecified |
Comment(by madi):
please try r51063. If you get the error message: "grass.script can't be
imported." please read
http://grass.osgeo.org/wiki/GRASS_and_Python#Creating_Python_scripts_that_call_GRASS_functionality_from_outside
in order to adjust the paths of grass variables.
madi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.hazard.flood.py
  Platform: MSWindows 7 | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
No more response, closing as fixed. Reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1613#comment:7&gt;
