[GRASS-dev] [GRASS GIS] #1621: nviz broken under Ubuntu 64 bit
Reporter: lutra | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone:
Component: Tcl/Tk NVIZ | Version: 6.4.1
Keywords: | Platform: Linux
      Cpu: x86-64 |
I just tested on a couple of machines with Ubuntu 64 bit (one 11.04 and
the other 11.10) and when running nviz I get
nviz elevation=dem@etrs89
Loading raster map ...
Translating colors from raster map ...
X Error of failed request: BadRequest (invalid request code or no such
operation)
   Major opcode of failed request: 136 (GLX)
   Minor opcode of failed request: 19 (X_GLXQueryServerString)
   Serial number of failed request: 248
   Current serial number in output stream: 248
Finished with error
On a 32 bit machine it works fine (same GRASS version as above 6.4.1-2 and
Ubuntu 11.10)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1621&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by marisn):
  * status: new => closed
  * resolution: => invalid
Comment:
This looks like system OpenGL issue. Reopen if NVIZ is the only OpenGL
application failing. In such case, please, attach the output of glxinfo.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1621#comment:1&gt;
