[GRASS-dev] [GRASS GIS] #1711: Plot settings in profiler now broken
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
The plotting settings in the wxGUI profiler have been recently broken in
GRASS 6.4 svn. When I try to access them (using the NC demo data), I get
the following error:
Settings: unable to get value 'profile:raster:None'
   File "/Applications/GRASS/GRASS-6.4.3.app/Contents/MacOS/e
tc/wxpython/wxplot/base.py", line 489, in PlotOptions
title = _('Plot settings'))
tc/wxpython/wxplot/dialogs.py", line 455, in __init__
wx.Dialog.__init__(self, parent, id, title, style = style,
**kwargs)
tc/python/wx/_windows.py", line 651, in __init__
_windows_.Dialog_swiginit(self,_windows_.new_Dialog(*args,
**kwargs))
TypeError
'plottype' is an invalid keyword argument for this function
This is on a version compiled 23 August
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711&gt;
      Cpu: Unspecified |
Comment(by annakrat):
The problem is that when you fix this error, another appears which is
probably caused by the major gui backport half a year ago. I am not sure
how the wxplot tools are tested in grass 7 but I think now it would be
easier to copy all wxplot from 7 to 6.4 (no idea what is in 6.5). In
general it is quite difficult to maintain two different versions of gui
since classes in wxGUI are connected together (which is a sign of not well
designed class model).
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:1&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
I echo these difficulties.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:2&gt;
      Cpu: Unspecified |
Everything works fine with GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:3&gt;
      Cpu: Unspecified |
I spoke too soon. You can open the settings in GRASS 7 and some of them
work. But hitting apply or save raises the following error:
   File "/Users/Shared/grass_dev/grass70_dev/macosx/dist/GRAS
S-7.0.app/Contents/MacOS/etc/gui/wxpython/wxplot/dialogs.py"
, line 1231, in OnApply
self.parent.SetGraphStyle()
S-7.0.app/Contents/MacOS/etc/gui/wxpython/wxplot/base.py",
line 299, in SetGraphStyle
self.client.SetEnableGrid(self.properties['grid']['enabled']
S-7.0.app/Contents/MacOS/etc/python/wx/lib/plot.py", line
895, in SetEnableGrid
self.Redraw()
1264, in Redraw
self._Draw(graphics,xAxis,yAxis,dc)
1258, in _Draw
self._adjustScrollbars()
1855, in _adjustScrollbars
r_max = list(self._getYMaxRange())
1067, in _getYMaxRange
yAxis = self._axisInterval(self._ySpec, p1[1], p2[1])
1665, in _axisInterval
raise ValueError, str(spec) + ': illegal axis specification'
ValueError
{'max': 0.0, 'type': u'auto', 'log': False, 'min': 0.0}:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:4&gt;
      Cpu: Unspecified |
I can't reproduce this error. However I can see some inconsistency in the
settings - when you change value (color, text) of certain widgets the
change is automatically applied on the graph. But this doesn't work for
all widgets. When the dialog has Apply button, these changes should apply
only after clicking on the button and not earlier.
After pressing Save you get this output in console: Plot settings saved to
file 'None'.
The settings file is changed but I cannot see the changed values.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
Not sure how much it is related to this ticket, but r53039 fixed the
settings for the profile tool. Successfully tested under XP, profile tool
is back working.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:6&gt;
      Cpu: Unspecified |
OK, maybe not related. This error remains:
Map display -> Profile Icon -> Settings -> Plot Settings:
   File "C:\Programmi\GRASS GIS
6.4.3svn\etc\wxpython\wxplot\base.py", line 472, in
PlotOptions
6.4.3svn\etc\wxpython\wxplot\dialogs.py", line 495, in
__init__
self._do_layout()
6.4.3svn\etc\wxpython\wxplot\dialogs.py", line 568, in
_do_layout
size = (120, -1), choices = self.linestyledict.keys(), style
= wx.CB_DROPDOWN)
   File "C:\Programmi\GRASS GIS 6.4.3svn\Python27\lib\site-
packages\wx-2.8-msw-unicode\wx\_controls.py", line 494, in
__init__
_controls_.Choice_swiginit(self,_controls_.new_Choice(*args,
**kwargs))
wx._core
PyAssertionError
C++ assertion "!(style & wxCB_DROPDOWN) && !(style &
wxCB_READONLY) && !(style & wxCB_SIMPLE)" failed at
..\..\src\msw\choice.cpp(121) in wxChoice::Create(): this
style flag is ignored by wxChoice, you probably want to use
a wxComboBox
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:7&gt;
      Cpu: Unspecified |
Markus,
This seems like a Windows-specific problem. Can you tell me a bit more
specifically what things do and do not work so I can check on it?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:8&gt;
      Cpu: Unspecified |
On XP, the bug is triggered when starting the profiler tool and going to
settings:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:9&gt;
      Cpu: Unspecified |
OK. I'm pretty sure I fixed this. CB_DROPDOWN is not a valid style for
wx.Choice, but for wxComboBox. I guess nix and Mac don't care, but Windows
does. There was a mix of mostly wx.Choice controls and a couple
wx.ComboBox controls on the options dialog. I made them all wx.Choice for
consistency and got rid of the invalid style.
Please test r5348.
PS: is there any way to add a cc on a ticket? There used to be I thought
but I can't find it now. I'd like to cc Anna.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:10&gt;
      Cpu: Unspecified |
That should be r53048
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:11&gt;
      Cpu: Unspecified |
Replying to [comment:11 cmbarton]:
Yes, it fixes the problem to open the plot settings dialog. Unfortunately
one more now
when changing settings therein and clicking Apply/OK:
6.4.3svn\etc\wxpython\wxplot\dialogs.py", line 867, in OnOk
self.OnApply(None)
6.4.3svn\etc\wxpython\wxplot\dialogs.py", line 860, in
OnApply
self.UpdateSettings()
6.4.3svn\etc\wxpython\wxplot\dialogs.py", line 837, in
UpdateSettings
self.properties['marker']['type'] =
self.FindWindowById(self.wxId['marker']['type']).GetValue()
AttributeError
'Choice' object has no attribute 'GetValue'
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:12&gt;
      Cpu: Unspecified |
OK. Back now and will check on this. Thanks for testing.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:13&gt;
      Cpu: Unspecified |
Try r53049
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:14&gt;
      Cpu: Unspecified |
added tooltips as per Anna's suggestion and tweaked labels in options in
r53049
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:15&gt;
      Cpu: Unspecified |
Also updated GRASS 7 with same fixes. I'll try to see how best to update
6.5.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:16&gt;
      Cpu: Unspecified |
It looks like GRASS 5 devbranch (AKA 6.5) is enough like 6.4.3 to allow
backporting for the profile fixes. So I've done this. Please test. If all
is well, we can close this.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:17&gt;
      Cpu: Unspecified |
I've tested on Mac for 6.4.3, 6.5, and 7. Work for me in all branches.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:18&gt;
      Cpu: Unspecified |
Works now in 6.4.svn also on XP and Linux, thanks!
I did not test 6.5 and 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:19&gt;
