[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
Reporter: antonioall | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: v.in.lines | Platform: MSWindows 7
      Cpu: x86-64 |
Hello,
The file Coordinate.txt is:
496174.445494,4553975.166661,429.9415
495577.433542,4556363.214470,372.9797
NaN,NaN,NaN
497882.563024,4554290.256303,370.0215
NaN,NaN,NaN
NaN,NaN,NaN
497899.146689,4556479.300127,382.7335
NaN,NaN,NaN
NaN,NaN,NaN
The Text of Error is:
(Mon Sep 10 10:44:48 2012)
v.in.lines -z input=C:\myPATH\Coordinate.txt output=prova fs=,
C:/GRASS GIS 6.4.3svn/scripts/v.in.lines: line 108:
/otherMyPath/PERMANENT/.tmp/4520.0: No such file or
directory
head: cannot open `/otherMyPath/PERMANENT/.tmp/4520.0' for reading: No
such file or directory
ERROR: Not enough data columns. (incorrect fs setting?)
(Mon Sep 10 10:44:48 2012) Comando terminato (0 sec)
Best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727&gt;
      Cpu: x86-64 |
Description changed by neteler:
Old description:
Hello,
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
directory
Best regards
New description:
Hello,
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
NaN,NaN,NaN
directory
Best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:1&gt;
      Cpu: x86-64 |
Comment(by neteler):
Please post the true path, I suspect that it contains white space.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:2&gt;
      Cpu: x86-64 |
Comment(by hamish):
AFAICT everything in 6.x is quoted,
L108 reads:
       tr "$fs" ' ' < "$GIS_OPT_INPUT" > "$TEMPFILE"
your test data works for me on Windows XP 32bit using 6.4.2 with the data
file stored in 'C:\Documents and Settings\...', even from the wxGUI with
file selected using the open file browser and without adding any
additional quoting (so bug #1447 was not a problem)
you put the version as trunk but the milestone at 6.4.3. Which version of
grass did you see this in?
Hamish
(trac still logs me out every bloody time I comment on a ticket! argh)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:3&gt;
      Cpu: x86-64 |
Comment(by hamish):
maybe the path contains a UTF8 char?
the module (the error looks like it comes from 6.x version of the script)
should edit with an error if it couldn't create the temp file.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:4&gt;
      Cpu: x86-64 |
Comment(by antonioall):
Hello,[[BR]]
yes, the path of the database contains a white space because the name of
the folder of the database is "GIS<space>Database", that is the name
assigned by Grass of default during the first installation.
Thanks,[[BR]]
Best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:5&gt;
      Cpu: x86-64 |
Comment(by hamish):
Hi, just testing with the latest wingrass 6.5 nightly build.
Your example works for me from the MSYS terminal, but not from the cmd.exe
dos box prompt, as it can't find v.in.mapgen when called from within the
v.in.lines script -- the old problem of calling scripts from inside of
scripts is back, at least for the dos box.
looking at the v.in.mapgen.bat file in $GISBASE/bin/ I see that all the
auto-gen .bat files there have UNIX line endings in them. (extra char
shows up in notepad.exe)
Seems that we need to do more unix2dos calls in the Makefiles to fix those
(what changed?). In this case it doesn't fix it; also from the dos box
window also module guis and g.gui fail with "no module named
grass.script".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:6&gt;
Priority: critical | Milestone: 6.4.3
Keywords: v.in.lines, g.tempfile | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: v.in.lines => v.in.lines, g.tempfile
  * priority: normal => critical
Comment:
ok, I can reproduce the error on XP 32bit with the latest nightly 6.5
wingrass build, if I run it from the wxGUI File->Import vector data menu.
directory
the problem seems to be with g.tempfile, it's leaving the C: off the temp
file name.
It creates the tempfile ok, but I think in the script it needs to start
with "/c/" ?
.. right, changing v.in.lines to:
  TEMPFILE=/c"`g.tempfile pid=$$`"
allows v.in.lines process the temp file. (but then v.in.mapgen chokes on
its tempfile).
`g.tempfile pid=123` run from the wxGUI Command Console shows the same
behaviour: the tempfile name in the output canvas is "/Documents and
Settings/Username/My Documents/GIS DataBase/spearfish60/user1/.tmp/123.0",
without /c or C: to start it.
(also not very good if you data is on D: but grass is installed to
C:\Program Files)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:7&gt;
      Cpu: x86-64 |
Comment(by hamish):
the GISDBASE string without `/c/` or `C:\` is coming directly from
g.gisenv's GISDBASE setting. (via lib/gis/gisdbase.c's G_gisdbase())
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:8&gt;
      Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:8 hamish]:
g.gisenv's
that's it: editing the C:\Docs and Settings\Username\Application
Data\GRASS6\grassrc6 file while GRASS is not running, or just adding "c:"
in the GISDBASE box in the grass startup screen, allows v.in.lines to find
its tempfile and import the file correctly.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:9&gt;
      Cpu: x86-64 |
Comment(by hamish):
Attempt at giving the script .bat files DOS line endings committed to
devbr6 in r55904. hopefully it helps for that part of the problem.
I'm not sure how GISDBASE was losing its C: part, removing the
%APPDATA%/GRASS6/grassrc file and starting over it puts it in and
v.in.lines works...
the wingrass grassrc6 file is originally created by lib/init/Init.bat, and
GISDBASE there by `%USERPROFILE%" | g.dirseps -g`, which preserves the
full thing.
Maybe the result of some historical left-over, but it happened to both me
and antonioall ..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:10&gt;
      Cpu: x86-64 |
Replying to [comment:10 hamish]:
Backported to relbranch64 (r55922) to get it into 6.4.3RC3
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.lines, g.tempfile
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by antonioall):
  * status: new => closed
  * resolution: => fixed
Comment:
Hello,
I tested v.in.lines in version 6.4.3RC3 and work well.
Thank you
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:12&gt;
Comment(by hamish):
How C: got lost from GISDBASE for both of us is still a mystery, but now
we know what to look out for.
reopen if it comes back..
we also need to test it from the CMD.EXE grass Command Line in 6.x before
forgetting about it.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:13&gt;
Comment(by hamish):
DOS newlines in the bin/*.bat files seem ok, but the script-called-from-
within-a-script does not yet work in the current cmd.exe Command Line
grass, see #1845, so v.in.lines fails there.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:14&gt;
Comment(by hamish):
make that ticket #1945, first comment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:15&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: v.in.lines, g.tempfile
  * status: closed => reopened
  * resolution: fixed =>
Comment:
nope, not fixed. the GRASS Command Line startup option just ate the C:
part of my GISDBASE again in %APPDATA%/GRASS6/grassrc6. (latest 6.5svn
nightly build)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:16&gt;
* cc: marisn (added)
Comment:
it's the `GRASS GIS 6.x Old TclTk GUI` startup menu item which is eating
the C: part of GISDBASE.
specifically this line in lib/init/gis_set.tcl:
if { [regexp -- {^GISDBASE.*:(.*)$} $thisline dummy env_database] } {
     set database [string trim $env_database]
looking into why it isn't like `{|^GISDBASE: \(.*\)$}` already with 'svn
blame', looks like r45817 introduced it. Maris, do you remember what the
problem is that was fixing, so we can avoid reintroducing it?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:17&gt;
Comment(by hamish):
Glynn suggested the reason that the script-with-a-script was not working
from the C:\> Command line version of wingrass 6.x was that the
$GISBASE\scripts dir was missing from the %PATH% there. This is indeed the
case, and adding it to the %PATH% allows v.in.lines (and any other script
which calls another shell script) to run successfully.
$GISBASE/bin is in there twice, that will need a test-before-adding too
(maybe in env.bat?)
tcl/tk eating the C: string remains open.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:18&gt;
Comment(by hamish):
re. script-called-from-a-script failure from the 6.x wingrass Command Line
and GIS.m, here's a patch.
Index: lib/init/init.bat
--- lib/init/init.bat (revision 56002)
+++ lib/init/init.bat (working copy)
@@ -24,8 +24,10 @@
  set SAVEPATH=%PATH%
  rem
-rem DON'T include the scripts/ directory in PATH -- The .bat files in the
-rem bin/ directory are what execute the scripts on Windows.
+rem The .bat files in the \bin directory are what execute the scripts
+rem on Windows. The \scripts dir is added to the PATH automatically by
+rem the wxGUI; for Command Line mode and GIS.m, shell scripts called
from
+rem other shell scripts need to have %GISBASE%\scripts in the PATH.
  rem
  if exist "%APPDATA%\GRASS6\env.bat" (
@@ -121,9 +123,12 @@
         set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python
-if "%GRASS_GUI%"=="text" goto text
  if "%GRASS_GUI%"=="wxpython" goto wxpython
+PATH=%PATH%;%GISBASE%\scripts
+if "%GRASS_GUI%"=="text" goto text
+rem Tcl/Tk GUI setup
  if not "%GRASS_WISH%"=="" (
         "%GRASS_WISH%" "%GISBASE%\etc\gis_set.tcl"
  ) else (
any comments before committing it?
Hamish
Ticket URL: <Making sure you're not a bot!;
