[GRASS-dev] [GRASS GIS] #1742: WXGUI layer manager window doesn't show all menubar entries
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: Linux
      Cpu: Unspecified |
When starting WXGUI in non-english language, Layer Manager window is too
narrow to display all menubar entries.
Steps to reproduce:
  * start WXGUI in German
Setting as blocker, as with German version there's not even a slightest
hint that "Datenbank" and "Hilfe" entries are missing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742&gt;
      Cpu: Unspecified |
Comment(by neteler):
I second this - this applies to many translations.
(Obvious, sorry) suggestion: autocalculate the width of the window as it
is already
done in some wxGUI windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:1&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:1 neteler]:
is already
There is another problem which is connected to this one (probably obvious
too). If you make Layer Manager window bigger (manually as a user or
programmatically) on small monitors there will be not enough space to have
Layer Manger and Map Display side by side unless you will make Map Display
thinner (but then it will be not useful). I can see only one solution for
that: One big window for layer manager's and map display's widgets
([http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012#wxGUI GSoC ideas,
wxGUI, point 3]).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:2&gt;
      Cpu: Unspecified |
Comment(by annakrat):
is already
I couldn't find a way to determine the menubar length, it always gives me
only the width of the frame itself.
Is this really a blocker? It's the standard behaviour of wxWidgets. There
is also some custom menu - wx.FlatMenu - however from the demo I can see
that this problem is solved only for too long toolbar and not for the
menu.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:3&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:3 annakrat]:
There is also some custom menu - wx.FlatMenu - however from the demo I can
see that this problem is solved only for too long toolbar and not for the
menu.
I can hardly agree with blocker status... Please change the priority to be
more realistic, otherwise we will never release 6.4.3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 martinl]:
menu.
be more realistic, otherwise we will never release 6.4.3.
For Ubuntu 12.04 (with Unity) it is definitively not a blocker considering
[https://wiki.ubuntu.com/global_menu global menu bar] and
[http://www.techrepublic.com/blog/opensource/ubuntus-hud-light-years-
beyond-any-menu-system/3535 HUD].
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:5&gt;
Priority: critical | Milestone: 6.4.3
      Cpu: Unspecified |
Changes (by martinl):
  * priority: blocker => critical
Comment:
Downgrading priority...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:6&gt;
      Cpu: Unspecified |
Also note that on Windows the menu is automatically wrapped.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:7&gt;
Priority: critical | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by wenzeslaus):
  * milestone: 6.4.3 => 7.0.0
Comment:
Although the long menu is unpleasant and we want to solve this problem, it
is not planed to solve it for 6.4.*. Currently only ideas how to solve
this problem are:
  * one big single
(http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/SingleWindow) window
  * or toolboxes and thus possibly shorter menu
(http://grasswiki.osgeo.org/wiki/Toolboxes, probably
http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes in the
future).
Both ideas are valid only for 7. Moreover, for MS Windows (with wrapped
menu), Mac and Ubuntu with Unity (with global menu) it is not such a
critical problem.
So, changing milestone to 7.0.0 (i.e., for 6.4.3 it is closed as wontfix).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:8&gt;
      Cpu: Unspecified |
Replying to [ticket:1742 marisn]:
> too narrow to display all menubar entries.
On Windows8 this is no longer the case, the menu is being wrapped to
to lines.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:9&gt;
      Cpu: Unspecified |
''This is not going to be fixed soon, especially if it affects only some
systems and some languages, so for now I just recap solutions.''
== Possible solutions ==
=== Fix the system library ===
  * fix the system GUI library
  * we can say that the system library handles long menus in the wrong way
(hides items withou notifying a user)
  * hidden items itself are in fact not problem of GRASS but of the system
GUI library (maybe it is a problem of wxPython/wxWidgets but probably not)
=== Single window GUI ===
  * redesign the wxGUI to big single window which can have a long menu
  * this would solve it, but we still want to have current multi window
GUI and for this the problem would be still present
=== Bigger Layer Manager window ===
  * make Layer Manager window bigger
  * no point in this, width is needed for menubar (and toolbars) but
usually not for the content itself
=== Abbreviations ===
  * use abbreviations in the menu (in English? in translations?
optionally?)
=== Shorter menu ===
  * create a shorter menu (but what shall be omitted?)
  * create a shorter menu using toolboxes for yourself
   * possible now, see
[http://grass.osgeo.org/grass70/manuals/wxGUI.toolboxes.html user manual
page]
   * only workaround, each affected user must do it
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:10&gt;
      Cpu: Unspecified |
Comment(by hamish):
some 2c comments:
  * IMO abbreviations should be avoided in almost all situations. the
learning curve and new jargon is hard enough to decipher already,
especially for non-native speakers trying to figure out what a 4-5 letter
non-word is supposed to mean.
  * re. looks ok on Unity: it's one window manager among many, in one
distro among many, of one operating system among several. Maybe it has a
big market share for us, but I wouldn't think to design anything around it
or suggest it to anyone as a solution to the menu error.
  * it's important. we should make it work on all languages. ("missing"
tabs in module guis is another related issue, the filled triangle is hard
to see)
  * my vote for a quick fix is to start by making the layer manager
starting width a bit bigger (module guis too). (also good for the output
window/tab) see also ctrl-t tile window wish/patch: #2004
  * Please, for the love of all that is good an right in the world: don't
name the personal menu as "My Favorites". Anything but that. (mmph,
"Custom"?)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1742#comment:11&gt;
      Cpu: Unspecified |
Replying to [comment:11 hamish]:
> abbreviations... Unity...
Agreed.
> ("missing" tabs in module guis is another related issue, the filled
triangle is hard to see)
This is reported in #306 and should be improved (or even fixed) by r52927,
maybe we need to change the default settings now.
starting width a bit bigger.
Unfortunately, there is always some language with extreme word-length. But
yes, we can try to set the width e.g., for German, but, as I noted
earlier, I'm afraid that this will create too big layer manager window (I
think I've already tried).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1742#comment:12&gt;
Keywords: menu | Platform: Linux
      Cpu: Unspecified |
  * keywords: => menu
Comment:
''update for comment:10''
Toolboxes XMLs now (after r57187, r57188 and r57199) provide possibility
to have different tree for ''main menu bar'' and for the ''module tree''
in module search tab. It is not yet in documentation but it's the same as
previous version but now there are two files (main_menu and module_tree)
used by GUI.
We can reduce the number of main entries in main menu: remove Database,
Imagery or Volumes item because they are in the module tree. This is a
change in philosophy of wxGUI of course. However, it's no so big because
Temporal (framework) item was newer in the menu, it's only in the module
tree (the same applies also for special Addons and Custom toolboxes
items).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:13&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
This wish/issue has been around since the TclTk menus. The screenshot
attached shows what appears to be a low resolution, small monitor,
creating a small layer manager with large type. This is exacerbated by
long menu entries in German. I agree with Hamish that while we definitely
want GRASS to work across multiple languages, we should not make the
interface worse for the majority to satisfy a minority of users. So we
need to understand the true extent of this problem. So here are a few
questions and comments.
1. The current menu words in English were picked because they were
relatively short. Rather than direct translation to another language, can
the same concepts be expressed in shorter words? It is the concepts that
are important, not the actual words used in the menus. This is something
those who work on the translations can best consider and answer.
2. On the smaller monitor of my MacBook Air, the absolute (i.e., in mm)
size of the type is smaller because more pixels are crammed into smaller
screen real estate. Is this primarily a problem on small monitors with
average or lower resolutions (e.g., notebook computers)?
If so, we need to think about whether this is the main GRASS user
audience. While it would be nice to run GRASS on a notebook (and a number
of student do so here) those platforms are not really very good for GIS
work. While it is really great that GRASS works on such platforms, I'm
reluctant to optimize the GUI for such platforms.
The menu structure (horizontal menu bar, pull down menu item lists, sub-
menus) is very traditional. However, this in and of itself tends to be
best at optimizing limited screen real estate (i.e, small displays). A top
level list of menu items can be horizontal, vertical, or in a rectangular
matrix. All current displays are longer horizontally than they are
vertically. So, especially for long words, you can get more textual
information while using up less available screen space in a horizontal
menu than in either of the other 2 options, because each menu entry only
takes up the width of the menu word. For a vertical set of menus, each
entry takes up the space of the longest word in the entire menu. Block
matrices are similarly affected.
One solution is to allow the user to alter the menu font size in the
preferences. It could then be set for different display environments by
the user. Another solution is to replace the words in the top level menu
with more icons. The possible draw back is that icons may not be easily
understandable to novice users (see below). But with mouse over text, they
can be learned relatively easily.
3. Currently, it is relatively easy to find and access all functions in
GRASS--in spite of the fact that it is a very complex program with
hundreds of modules--because of the current menu design. Early in the
current GUI design process, one of the devs (I don't remember which one)
noted that good menu design should keep all selections within a maximum of
3 levels of nesting (top menu, pull-down, and sub-menu). This has been a
very good principle to follow. One of the complaints I regularly hear
about Arc is how difficult it is to find different functions, being nested
in menus, leading to tool boxes, leading to dialogs and more menus.
The current GUI attempts to group functions according to work flow.
Functions for making and altering maps are in the menus, functions for
arranging maps for viewing are in the layer manager. Functions for
interacting with displayed maps are in the map display windows. I'm in
favor of experimenting with new designs for ways to access different
functions. But the top priorities in any GUI should be ease of access,
transparency in signaling, and facilitating work flows. Users should be
able to find and identify the tools they need as quickly and as easily as
possible as they need them. So I remain skeptical of tool boxes and don't
like the idea that users will need to access yet another interface (e.g.,
hierarchical module list) from the primary interface to find a needed
function. As much as possible should be accessible at a glance, while
minimizing the loss of total screen space--which is best used to display
maps.
These are just some musings. We need to be innovative but for the GUI keep
in mind novice rather than expert users.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1742#comment:14&gt;
      Cpu: Unspecified |
I added a patch to adjust lmgr frame minimal width according to ideal menu
width (attachment:lmgr_width_for_menu.diff).
But:
  * it adjusts minimal size, not the real size, so user cannot make lmgr
frame smaller; implement it for the (non-minimal) size is difficult (there
are default values and user settings involved)
  * width is only estimated, I put there some magic constants which worked
for en, cs and de on Ubuntu
  * it should do nothing for English but the locale test fails on some PCs
returning None; locale is always fragile
It is too complex I think and I'm now not sure if it was worth to even try
to write this patch, but since it is written I posted it here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:15&gt;
      Cpu: Unspecified |
Hamish wrote on ML ([GRASS-dev] GRASS GIS 7 tech-preview release
preparations):
> I welcome better presentation of the menus since they get rather big
(platoon rule of thumb: any more than ~12 in any level/group gets a bit
overwhelming), but wrt "search to run" as the primary instead of
augmenting method, I fear that way is not very discoverable -- at least
I'd like to avoid the situation where a new user needs to know the name of
what they're looking for before they can find it, which isn't so good to
explore & learn about new modules you don't know exist yet. Especially for
a software so big as ours which takes years to fully know.
Look at the 'Search modules' in lmgr. There is a search box but also a
tree which you can browse.
> We are spatial creatures, so a spatial model for menu layout where we
can use our spatial & muscle memories helps I think. Our monitors are
getting really wide these days, both desktop and laptop, and so top menu
bars will fit even better than they used to, we just have to make the
windows a bit wider to compensate. Luckily these days there's space for
that. (2c)
Bit wider is not enough for German, it has to be much bigger.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:16&gt;
      Cpu: Unspecified |
I've committed a wider lmgr in r57518. It does nothing for MS Windows, Mac
OS X and Ubuntu with Unity (UBUNTU_MENUPROXY properly set).
It does nothing if you have some settings, so `mv .grass7 .grass7.1` to
test this.
I'm don't like it because for English it creates bigger lmgr than needed
(on the other platforms) and it is far from being general language-
independent. But yes, user can and probably will change it in the settings
(save current win layout), but this was possible before the change, too.
We can change the constant if needed. It works for German and Ubuntu
without global menu.
If this is what we want, close the ticked. If it is not, revert r57518.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:17&gt;
      Cpu: Unspecified |
Replying to [comment:16 wenzeslaus]:
preparations):
that. (2c)
I can make the window MUCH wider if I want and then save it so that it
opens that wide every time I start the GUI afterwards. So I'm not sure I
understand the problem. It seems that the issue is a combination of having
long words for menu headings, small displays, and low resolution. Or do I
misunderstand? If this is the crux of it, I'm not convinced that we should
rework the entire GUI for all other GRASS users in order to deal with that
specific problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:18&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:17 wenzeslaus]:
I can confirm that this creates a nicer initial contact for French-
speaking users as you can now see all menus at startup. +1 for keeping
this patch.
A similar issue (but maybe for a separate ticket): the wxdigitizer in the
map display has a row of buttons that is too long for the map display,
hiding the 'exit' button that I find quite essential. If one does not know
that it exists, there is not indication for the user to look for it...
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1742#comment:19&gt;
