#1755: cannot create sqlite table for v.net.centrality
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Vector | Version: unspecified
Keywords: v.net.centrality | Platform: Unspecified
Cpu: Unspecified |
I just tried v.net.centrality so I could present it to class tomorrow.
Apparently it is broken.
I got the error:
v.net.centrality input=roads_nodes@spatialtech2012 alayer=1 nlayer=2
output=roads_cent degree=degree closeness=close betweenness=between
eigenvector=eigenvect
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "between": syntax error
ERROR: Unable to create table: 'create table roads_cent(cat integer,
degree double precision, close double precision, between double precision,
eigenvect double precision)'
(Thu Oct 4 22:10:04 2012) Command finished (0 sec)
There is an old request to quote column names that would allow to use SQL
reserved words as column names. See more: #578
Second option would be to enhance parser to discard SQL reserved words as
valid column parameters. AFAIK SQL-92 reserved word list isn't so long.
Yes, I know, somebody will scream that PG, MySQL etc. have extra reserved
words etc., still even blocking only the most common ones would make day
for a user like Michal much better as he would be able to finish his task
instantly instead of writing a bug report.
#1755: Need error message to indicate reserved words in SQLite
Cpu: Unspecified |
Changes (by cmbarton):
* type: defect => enhancement
Comment:
I relooked at the error and I'm not as unobservant as I initially assumed.
There is nothing to say that "between" is an SQLite reserved word. So
thanks for the clue about what is wrong.
This is not a bug. But maybe an enhancement request for better error
messages here. Changing the field name to "betw" makes it work fine. I've
changed the summary too. I don't know if the component should stay vector
or shift to something else.
