GDAL
October 23, 2012, 12:27pm
1
#1767: v.univar: add sum
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: unspecified
Keywords: v.univar | Platform: Unspecified
Cpu: Unspecified |
I was surprised to discover that v.univar does not print out the sum of
the variable asked for. The attached very simple patch (against
64_release) does that. Was there any reason I should know about why the
sum was not included ?
And: is it acceptable to add the sum to grass6, or is this an unacceptable
change in behaviour of a module and should only be added to grass7 ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1767> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
October 24, 2012, 7:29am
2
Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.univar
Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Since it is an "easy" patch, added to G6.4-G7 in r53533, r53534, 53535.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1767#comment:1> ;
GDAL
October 24, 2012, 7:42am
3
Comment(by mlennert):
Replying to [comment:1 neteler]:
Thanks. I just hope that this will not perturb any scripts that depend on
v.univar output being in a specific order...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1767#comment:2> ;
GDAL
October 24, 2012, 9:09am
4
Comment(by neteler):
In the first place eval and -g flag should be used.
Then I don't see any v.univar usage the official scripts
not in the C code. Should be fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1767#comment:3> ;
