#1797: r.li.padcv broken
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Default | Version: 6.4.3 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
r.li.padcv is broken and gives the error listed below.
The selection control for the "output raster map" is also partly broken in
that it cannot select an existing map (although you can type the name).
This is broken in all r.li.* modules AFAICT.
Finally, the load configuration file control should default to the place
where configuration files are stored, which it does not (also in all
r.li.* modules). This may be a Mac issue but is probably affects all OS's
Someone who knows these modules should give them a test to make sure that
they work in GRASS 6.4.3 before release.
Error from r.li.padcv:
r.li.padcv map=landclass96@PERMANENT conf=testconfig output=testpadcv
ERROR: avlID_sub error
avlID_sub error
Cannot close
/Users/Shared/grassdata/nc_spm_08/spatialtech2012/.tmp/anthgradpc7.la.asu.edu/93307.10
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Cannot close
file (PIPE)
Cannot delete
file (PIPE)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1797>
