[GRASS-dev] [GRASS GIS] #1832: Python scripts are with mixed tabs and spaces
Reporter: klo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
I noticed that majority of python files in GRASS distribution are with
mixed tabs and spaces.
Mixing tabs and spaces is not good idea:
http://www.python.org/dev/peps/pep-0008/#tabs-or-spaces
In OSGeo4W, python files with mixed tabs and spaces can be found in these
folders and/or their sub-folders:
   C:\OSGeo4W\apps\grass\grass-6.4.3RC1\etc\gui\scripts[[BR]]
   C:\OSGeo4W\apps\grass\grass-6.4.3RC1\etc\python\grass\script[[BR]]
   C:\OSGeo4W\apps\grass\grass-6.4.3RC1\etc\wxpython[[BR]]
   C:\OSGeo4W\apps\qgis\grass\scripts[[BR]]
Same applies for grass-dev version (7.0)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832&gt;
Component: Python | Version: unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * component: Default => Python
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:1&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 martinl]:
I think that we need an option to resolve issues as "so what?". But
invalid or wontfix would suffice here.
Mixing tabs and spaces isn't inherently a problem, so long as no-one uses
something other than 8 column tabs (which is a bad idea for so many
reasons).
Even if we "fix" it for now, it will just keep creeping back in. Not all
GRASS developers work on GRASS and GRASS alone, and not all text editors
can easily be configured to automatically use different conventions for
different projects. So people will continue to commit changes which use
their text editor's default indentation.
The only permanent fix would be to configure the subversion server to
automatically convert files on upload (although that can create problems
of its own).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:2&gt;
      Cpu: Unspecified |
Comment(by klo):
Replying to [comment:2 glynn]:
"So what?" is lousy approach considering that sed one liner can fix it,
and I don't know of serious Python package on my system that mixes tabs
and spaces.
I reported and that's enough from me, as I don't plan to advocate PEP8,
but this is not like line exceeds 80th column. Mixing causes problems
especially in team work. Google it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:3&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
The problem is that we use 4 spaces indentation which really does not fit
with 8 spaces wide tabs. In my view, it causes confusion. Of course, you
often realize where is the problem, but is it necessary? (The is similar
for GRASS C code (#1663) but the problem for Python is more critical since
we don't and cannot have auto-indent tool for Python.)
Moreover, the problem of white spaces in GRASS Python code is larger. Try
to use pep8 tool, the result is really bad. I think that if there is some
standard, we should keep it, at least the basic rules.
I understand the problem of editor settings. I encountered it, too.
However, I also know the opposite problem. My Python editor is confused
and complains about GRASS code and thus it is sometimes hard to use
editor's code checking features.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:4&gt;
      Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:4 wenzeslaus]:
> Try to use pep8 tool, the result is really bad. I think that if there
> is some standard, we should keep it, at least the basic rules.
+1
However,
> I also know the opposite problem. My Python editor is confused and
complains
> about GRASS code and thus it is sometimes hard to use editor's code
checking
> features.
+1
why not use a pre-commit check, using pep8 like:
https://gist.github.com/2903822 # pep8 + pyflakes
http://widerin.org/blog/pep8-subversion-pre-commit-hook # only pep8
to force developers to use a standard?
Using a standard can help to have a consistent python code and make the
code easier to read.
Pietro
ps: pep8 command could be use also to convert all the existing python code
to comply the pep8 directive...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:5&gt;
      Cpu: Unspecified |
Comment(by hellik):
fit with 8 spaces wide tabs. In my view, it causes confusion. Of course,
you often realize where is the problem, but is it necessary? (The is
similar for GRASS C code (#1663) but the problem for Python is more
critical since we don't and cannot have auto-indent tool for Python.)
maybe it's worth to have a look to the original issue(but maybe not
related and worth for another ticket?):
http://lists.osgeo.org/pipermail/osgeo4w-dev/2012-December/001970.html
I don't know if this is relevant for this list, but while looking to patch
right file to stop QGIS GRASS plugin from spawning popup windows on every
command execution
as this can also be seen sometimes with osge4w/standalone-wingrass7
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:6&gt;
      Cpu: Unspecified |
Comment(by neteler):
Should this script be improved/GRASS'ified?: tools/reindent.py
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:7&gt;
Keywords: indent | Platform: Unspecified
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => indent
Comment:
Replying to [ticket:1832 klo]:
annoyingly, it asserts it is so but does not explain why. is it just that
lots of people submit code after editing with braindead text editors, or
is it something inherent in the python language which makes it so...?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:8&gt;
      Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:8 hamish]:
that
> or is it something inherent in the python language which makes it so...?
The problem is the inconsistency.
Python cleaned the syntax as much as possible, and use the space to define
the code block, using a mixed code can cause troubles [0,1] because you
are not consistent, and it is prone to errors.
Moreover in python3 file with mixed syntax will not work.
Personally I think that we must choose the style to use and add pre-commit
check consistently.
Using tabs to indent make problems when you want to aligned with opening
delimiter, like:
#!python
# Aligned with opening delimiter
foo = long_function_name(var_one, var_two,
                          var_three, var_four)
With spaces you are sure that the code look the same for all the
developers and not affect external source code viewers (e.g. the likes of
github, pastebin, etc).
Pietro
[0] http://www.jroller.com/larrywilliams/entry/mixing_tabs_and_spaces_in
[1] http://enjoydoingitwrong.wordpress.com/2009/03/24/mixing-tabs-and-
spaces-in-python/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:9&gt;
      Cpu: Unspecified |
Comment(by glynn):
that lots of people submit code after editing with braindead text editors,
Python uses indentation to determine block boundaries, so indentation
matters.
Some text editors treat tab stops as configurable, but there's no way for
the Python interpreter to know how the editor is configured, so it assumes
that tab stops are every 8 columns. If you use an editor which is set to
use e.g. 4-column tabs, then a line indented by 4 spaces and a line
indented by a tab will appear to be at the same indentation level, but
Python will treat the latter as indented more than the former.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1832#comment:10&gt;
