#185: division with dbf driver leads to protocol error
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0
Keywords: dbf division |
The help page on the dbf driver says "Arithmetic expressions using
constants and field values are allowed in condition clauses and in the RHS
of assignments".
I can confirm that these work:
v.db.update map=ilots col=prop_popmo value='P_UNDER_5+P5_TO_9'
v.db.update map=ilots col=prop_popmo value='P_UNDER_5-P5_TO_9'
v.db.update map=ilots col=prop_popmo value='(P_UNDER_5+P5_TO_9)*TOTAL_POP
However,
v.db.update map=ilots col=prop_popmo value='(P_UNDER_5+P5_TO_9)/TOTAL_POP'
gives me the following error:
ERROR: This should not happen: got a wrong expression structure after
parsing.
dbmi: Protocol error
ERROR: Error while executing: 'UPDATE ilots SET
prop_popmo=(P_UNDER_5+P5_TO_9)/TOTAL_POP
Ticket URL: <http://trac.osgeo.org/grass/ticket/185>
