[GRASS-dev] [GRASS GIS] #1925: Inherited Verbosity level for grass array .write()
Reporter: jradinger | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
as already discussed in the GRASS dev mailing list
[http://lists.osgeo.org/pipermail/grass-dev/2013-April/062902.html here] I
recommend respectively would like to see e.g. the python function write()
which is located
[http://svn.osgeo.org/grass/grass/branches/develbranch_6/lib/python/array.py
here] which writes an numpy array back into GRASS to behave like other
GRASS modules concerning the inheriting of the verbosity level.
At the moment the function sets verbose=TRUE and if the function is used
in a script the verbosity level is not inherited. I suggest to remove that
line (verbose=TRUE) which might be an relict since development times (see
mailing list discussion) and allow the inheriting. This issue might also
exist for r.in.bin (source: Hamish).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1925&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:1925 jradinger]:
Done in r55684.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1925#comment:1&gt;
      Cpu: Unspecified |
Comment(by jradinger):
Replying to [comment:1 glynn]:
> Done in r55684.
Thank you. But probably needs also to be back-ported to GRASS devel and
releasebranch.
And what about r.in.bin (don't know were it is located).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1925#comment:2&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 jradinger]:
What about it?
If you're referring to [http://lists.osgeo.org/pipermail/grass-
dev/2013-April/062929.html this message], you're misunderstanding his
comment. The issue is with grass.script.array passing verbose=True to
r.in.bin, not with r.in.bin itself.
The source is in raster/r.in.bin; the binary is in $GISBASE/bin.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1925#comment:3&gt;
oh sorry…yes that was a missunderstanding.
Cpu: Unspecified |
Comment(by glynn):
What about it?
If you’re referring to [http://lists.osgeo.org/pipermail/grass-
dev/2013-April/062929.html this message], you’re misunderstanding his
(don’t know were it is located).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1925#comment:3>
Component: Python | Version: unspecified
Keywords: | Platform: All
      Cpu: All |
Changes (by hamish):
  * platform: Unspecified => All
  * component: Default => Python
  * cpu: Unspecified => All
Ticket URL: <https://trac.osgeo.org/grass/ticket/1925#comment:4&gt;
Priority: normal | Milestone: 6.4.4
Component: Python | Version: svn-releasebranch64
      Cpu: All |
Changes (by neteler):
  * version: unspecified => svn-releasebranch64
  * milestone: 6.4.3 => 6.4.4
Comment:
> Done in r55684.
Should this change be backported to lib/python/array.py ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1925#comment:5&gt;
      Cpu: All |
Comment(by glynn):
Replying to [comment:5 neteler]:
Do you mean backported to 6.x?
If so: probably.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1925#comment:6&gt;
