[GRASS-dev] [GRASS GIS] #1941: wxGUI error
#1941: wxGUI error
Reporter: venkat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MSWindows 7
      Cpu: x86-32 |
I get following error with the wxGUI while running
GRASS7-svn when selecting modules form the menu.
on Windows-7 in Japanese locale.
I guess it is related to utf-8 encoding.
   File "C:\Program Files\GRASS GIS
7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 737, in
OnMenuCmd
cmd = self.GetMenuCmd(event)
7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 722, in
GetMenuCmd
input = GUI().GetCommandInputMapParamKey(cmdlist[0])
7.0.svn\etc\gui\wxpython\gui_core\forms.py", line 2301, in
gtask.get_interface_description(cmd).decode(enc).encode('utf
-8')))
UnicodeDecodeError
'cp932' codec can't decode bytes in position 7074-7075:
illegal multibyte sequence
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941&gt;
#1941: wxGUI fails with Japanese locale
      Cpu: x86-32 |
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:1&gt;
Keywords: wingrass | Platform: MSWindows 7
      Cpu: x86-32 |
Changes (by neteler):
  * keywords: => wingrass
Comment:
Two tickets related to cp932:
  * http://trac.osgeo.org/osgeo4w/ticket/294#comment:4
  * http://trac.osgeo.org/grass/ticket/1193#comment:2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:2&gt;
      Cpu: x86-32 |
Comment(by venkat):
This issue seems to have been fixed in GRASS-6.4 but I think still remains
in GRASS-7.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:3&gt;
      Cpu: x86-32 |
Comment(by mlennert):
Could this be related to #2021 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:4&gt;
      Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:4 mlennert]:
That seems unlikely, as this relates to Windows which doesn't use
environment variables for locale settings.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:5&gt;
      Cpu: x86-32 |
Comment(by improgrammer):
I encounter similar problem.
I suggest modifying the sementics of gtask.get_interface_description() to
return xml in "utf-8" encoding. see attachment
"patch_for_ticket_1941.patch".
Rational:
  1. The following code segment in task.py and forms.py is too limited
because ("cp936","cp932", etc) need similar converting:
     enc = locale.getdefaultlocale()[1]
     if enc and enc.lower() == "cp932":
         p = re.compile('encoding="' + enc + '"', re.IGNORECASE)
         tree = etree.fromstring(p.sub('encoding="utf-8"',
get_interface_description(name).decode(enc).encode("utf-8")))
     else:
         tree = etree.fromstring(get_interface_description(name))
  1. Any where the gtask.get_interface_description() is called, the
"convert-to-utf8" is needed;
  1. Properly constructed interface description text is xml text with
proper <?xml ... encoding="some-text-encoding"?> statement, extract text
encoding schema from these xml text is more rational than extract enc from
locale package.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:6&gt;
      Cpu: x86-32 |
Replying to [comment:6 improgrammer]:
to return xml in "utf-8" encoding. see attachment
> Rational:
> else:
locale package.
Can someone else working in a Japanese Windows environment test this patch
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:7&gt;
      Cpu: x86-32 |
Comment(by neteler):
Replying to [comment:7 mlennert]:
patch ?
Proposal: Since it so much easier to update winGRASS via installer, I
would suggest that we submit the patch to SVN and test from there. In
the worst case we revert after 24hs/whatever time.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:8&gt;
      Cpu: x86-32 |
Comment(by annakrat):
Replying to [comment:8 neteler]:
patch ?
Done in r57501. Please test!
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:9&gt;
      Cpu: x86-32 |
Replying to [comment:9 annakrat]:
patch ?
The related winGRASS 7 binary is now available here:
http://wingrass.fsv.cvut.cz/grass70/
as well as in OSGEo4W.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:10&gt;
      Cpu: x86-32 |
Comment(by venkat):
tried with WinGRASS-7.0.svn-r57518-685-Setup.exe
from http://wingrass.fsv.cvut.cz/grass70/ but this
gives me
ImportError: No module named gis when I try to start the
wxGUI. Details in the attachment.
Venka
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:11&gt;
      Cpu: x86-32 |
Replying to [comment:11 venkat]:
> gives me
You seem to have a problem with ctypes. I moved importing temporal gis
library (which apparently uses ctypes) so that wxGUI should at least
start.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:12&gt;
      Cpu: x86-32 |
Replying to [comment:12 annakrat]:
> > gives me
start.
Venka,
Have you been able to test these last changes ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:13&gt;
      Cpu: x86-32 |
Comment(by venkat):
Tried with WinGRASS-7.0.svn-r57622-697-Setup.exe and
get errors as shown in the attachment.
Thanks
Venka
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:14&gt;
      Cpu: x86-32 |
Replying to [comment:14 venkat]:
Please try the OSGeo4W installer, you shouldn't get this error there.
Anybody has an idea how to fix this annoying MAXREPEAT problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:15&gt;
      Cpu: x86-32 |
Replying to [comment:15 annakrat]:
Did you try this?
http://grasswiki.osgeo.org/wiki/WinGRASS_errors#Error_message_.22ImportError:_cannot_import_name_MAXREPEAT.22
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:16&gt;
      Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:16 neteler]:
> Did you try this?
Usually it's caused by Python installed together with Esri ArcGIS. The
newest version of ArcGIS 10.2 still comes with Python 2.7.3. It would be
good to find solution on our side without overwriting system-installed
Python.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:17&gt;
      Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:17 martinl]:
Python.
2.7.3 should be fine for GRASS, right? So the solution should be to detect
that the "system" Python is sufficient and not try to use the bundled
Python (i.e. don't set PYTHONHOME, set GRASS_PYTHON to point to the system
version, etc).
AFAICT, the issue is that the system python27.dll (from `Windows/System32`
or `Windows/SysWOW64`) is being used, but PYTHONHOME points to the bundled
version of the Python standard library.
If you can start a Python shell using the GRASS Python, you can use
[http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx Process
Explorer] to view the list of DLLs which are actually being used by that
process. AFAIK, System32/SysWOW64 take precedence over everything except
the directory containing the exe, and %PATH% comes last.
[http://msdn.microsoft.com/en-
us/library/windows/desktop/ms682586%28v=vs.85%29.aspx DLL Search Order].
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:18&gt;
      Cpu: x86-32 |
Replying to [comment:18 glynn]:
Python.
detect that the
No, the problem still remains. Note that we have this problem only with
standalone installer not with osgeo4w installer.
> "system" Python is sufficient and not try to use the bundled Python
version, etc).
But then we will have problem with other python packages (GRASS
dependecies) which are installed through osgeo4w environment as `python-
matplotlib` or `python-numpy`, right? Version of "system" python will be
most probably different from the python version available in osgeo4w
environment.
`Windows/System32` or `Windows/SysWOW64`) is being used, but PYTHONHOME
points to the bundled version of the Python standard library.
Strangely `C:\Program Files (x86)\GRASS GIS 7.0.svn\extrabin\python.exe`
launches python 2.7.3 (same as system python from `C:\Python27\ArcGIS
10.2`)! When launching `C:\osgeo4w\bin\python.exe` I got expected version
of python, so 2.7.4 (current osgeo4w python version). This partly explains
the fact that we have this problem only with standalone installer.
Right, when I launch `python.exe` which comes with standalone installer it
points to `C:Windows\SysWOW64\python27.dll`. When I launch `python.exe`
from `C:\OSGeo4W\bin` it points to the right dll file, ie.
`C:\OSGeo4W\bin\python27.dll`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:19&gt;
