[GRASS-dev] [GRASS GIS] #1957: v.in.ascii (points.c) does not import some numbers in attached example
Reporter: ychemin | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: v.in.ascii | Platform: Linux
      Cpu: x86-64 |
v.in.ascii input=9.csv output=rain_$(echo 9.csv | sed 's/\.csv//g')
separator=comma
Real number of columns: 4020
-----From v.in.ascii-----------
Maximum number of columns: 1366
Minimum number of columns: 1317
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957&gt;
Priority: normal | Milestone: 6.5.0
      Cpu: x86-64 |
Changes (by hamish):
  * milestone: 7.0.0 => 6.5.0
Comment:
(g6 filenames)
in vector/v.in.ascii/points.c change buflen from 4000 to 24000 or some
large enough value. consider also to increase BUFFSIZE from 128 in a2b.c
and `char buf[1000];` in in.c.
the dbf is still shortened, but that's a start.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
max dbf columns somewhere 255-1028+
   http://compgroups.net/comp.lang.clipper/maximum-fields-per-record-
dbf/888510
for sqlite: "`The default setting for SQLITE_MAX_COLUMN is 2000. You can
change it at compile time to values as large as 32767.`"
   http://www.sqlite.org/limits.html
PgSQL, "250 - 1600 depending on column types",
   http://www.postgresql.org/about/
MySQL, "There is a hard limit of 4096 columns per table, but the effective
maximum may be less for a given table."
   http://dev.mysql.com/doc/refman/4.1/en/column-count-limit.html
how many met stations? if less than the number of time records maybe
consider to invert the array and organize data by time instead of
position? or split up into multiple files by e.g. year?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:2&gt;
      Cpu: x86-64 |
Comment(by hamish):
hmm, aside from hardcoded sscanf() buffers, is there a max number of
columns in the grass 5 sites format?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1957#comment:3&gt;
      Cpu: x86-64 |
Comment(by hamish):
probably best to write a script to create one vector map per row, with
columns 3-inf rotated into a single column; and the timestamps in a second
column, matching the data by row number.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:4&gt;
      Cpu: x86-64 |
Comment(by ychemin):
Replying to [ticket:1957 ychemin]:
separator=comma
Merge Ticket 1958:
importing .csv made of several rows of 4020 columns each, import stops at
row 18, looking into the file, it is near the 20000 character.
Same behavior in 6.4.2 (Ubuntu stable version)
After setting (points.c):
76 buflen = 50000;
then error becomes:
Number of columns: 4020 <- THIS IS GOOD
DBMI-SQLite driver error:
Error in sqlite3_prepare():
too many columns on rain_9 <- :frowning:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:5&gt;
      Cpu: x86-64 |
Comment(by neteler):
Replying to [comment:5 ychemin]:
separator=comma
> 76 buflen = 50000;
For easier inspection:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c#L76
> then error becomes:
As mentioned, SQLite doesn't support more than 2000 columns out of the
box, for hints see
http://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Maximum_Number_of_Attribute_Columns
While the buffer in points.c could probably be enlarged, the latter is
a problem not related to GRASS GIS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.ascii
  Platform: Linux | Cpu: x86-64
Changes (by ychemin):
  * status: new => closed
  * resolution: => fixed
Comment:
I am closing this ticket,
enough information is there for people to choose how to handle it re:
sqlite.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:7&gt;
Comment(by hamish):
It is likely that even 255 columns will not be supported by grass, just
because the buffers are too small. Better to make the bottleneck the DB
backend not the GRASS frontend.
As a ballpark estimate, say 2 columns x,y at 10 chars wide, + 253 columns
of varchar(255), with field seps, plus a DOS newline,
  10 + 1 + 10 + 1 + 253*255 + 252 + 2 = 64791
I think it's also worth about the solutions of transposing the array and
creating a script to make each data row its own map, with the constant-
step time series as a single column not a series of individual rows.. work
around the DB limitation by thinking of the problem in a different way..
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:8&gt;
