#1960: wingrass wx carto composer: adding north arrow causes Error and traceback
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cartographic composer | Platform: MSWindows XP
Cpu: x86-32 |
testing latest 6.5svn nightly wingrass build.
If you open the wxGUI cartographic composer and pick 'add map element'
then 'North Arrow' you get a pop-up Error message window (screenshot
attached), twice, and the following different error message in the wxGUI
command console module output window:
File "C:\Program Files\GRASS GIS 6.5.svn\Python27\lib
\site-packages\wx-2.8-msw-
unicode\wx\lib\filebrowsebutton.py", line 140, in OnChanged
self.changeCallback(evt)
File "c:\Program Files\GRASS GIS
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4272, in
OnDirChanged
self.OnImageSelectionChanged(None)
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4317, in
self.ClearPreview()
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4386, in
ClearPreview
mask = wx.Mask(buffer, wx.WHITE)
\site-packages\wx-2.8-msw-unicode\wx\_gdi.py", line 1212, in
__init__
_gdi_.Mask_swiginit(self,_gdi_.new_Mask(*args, **kwargs))
wx._core
PyAssertionError
C++ assertion "!bitmap.GetSelectedInto()" failed at
..\..\src\msw\bitmap.cpp(1509) in wxMask::Create(): bitmap
can't be selected in another DC
6.5.svn\etc\wxpython\psmap\frame.py", line 676, in
OnAddNorthArrow
dlg = NorthArrowDialog(self, id = id, settings =
self.instruction)
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4490, in
__init__
imagePanelName = _("North Arrow"))
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4093, in
__init__
self.OnDirChanged(None)
OnDirChanged
self.ClearPreview()
ClearPreview
__init__
wx._core
PyAssertionError
and no image selection gui window. On my linux it works.
(the first half of the above is very similar to the traceback error in
#1959)
thanks,
Hamish
ps- todo: replace those eps with native GRASS symbols
Ticket URL: <https://trac.osgeo.org/grass/ticket/1960>
