#2003: wxGUI carto composer: traceback on exit
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: cartographic composer | Platform: Linux
Cpu: x86-64 |
I notice a traceback when exiting the wx cartographic composer.
File "/usr/lib64/python2.6/dist-
packages/wx-2.8-gtk2-unicode/wx/_misc.py", line 1342, in
Notify
self.notify()
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14716, in
Notify
self.result = self.callable(*self.args, **self.kwargs)
File "/home/hamish/src/grass/svn/relbr_6_4/dist.x86_64
-unknown-linux-gnu/etc/wxpython/psmap/frame.py", line 371,
in <lambda>
wx.CallLater(4000, lambda: self.SetStatusText("", 0))
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14564, in
__getattr__
raise PyDeadObjectError(self.attrStr % self._name)
wx._core
PyDeadObjectError
The C++ part of the PsMapFrame object has been deleted,
attribute access no longer allowed.
steps: start g.gui, select carto composer, make a map box, select a vector
map (I chose a points map from PERMANENT), preview ">", then close the
composer using the button on the far right. After a second the traceback
then appears in the wxgui output tab. (sometimes I have to do that 2-3
times for it to show up)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2003>
