#201: v.in.geonames wxGUI window crashes or freezes when "Verbose module output"
is checked
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
Details:
1. Download http://download.geonames.org/export/dump/PL.zip, unzip.
2. Run:
v.in.geonames &
from the terminal, select the geonames file, check "Verbose module
output", press Run - the window freezes and a backtrace is printed to the
terminal:
*** glibc detected *** menuform.py: double free or corruption (fasttop):
0x0000000001b62bf0 ***
======= Backtrace: =========
/lib/libc.so.6[0x2b43193c501d]
/lib/libc.so.6(cfree+0x76)[0x2b43193c6d26]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN10LineLayout4FreeEv+0x12)[0x2b43259b76e2]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN10LineLayoutD0Ev+0x17)[0x2b43259b7767]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN15LineLayoutCache8RetrieveEiiiiii+0x18f)[0x2b43259b7f4f]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN6Editor18RetrieveLineLayoutEi+0xa6)[0x2b43259b8076]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN6Editor5PaintEP7Surface10PRectangle+0x60b)[0x2b43259c22eb]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN11ScintillaWX7DoPaintEP4wxDC6wxRect+0xd1)[0x2b43259a1531]
/usr/lib/libwx_gtk2u_stc-2.8.so.0(_ZN16wxStyledTextCtrl7OnPaintER12wxPaintEvent+0x8f)[0x2b43259a8f6f]
/usr/lib/libwx_baseu-2.8.so.0(_ZN12wxEvtHandler21ProcessEventIfMatchesERK21wxEventTableEntryBasePS_R7wxEvent+0x7f)[0x2b431c167fdf]
/usr/lib/libwx_baseu-2.8.so.0(_ZN16wxEventHashTable11HandleEventER7wxEventP12wxEvtHandler+0x9f)[0x2b431c16817f]
/usr/lib/libwx_baseu-2.8.so.0(_ZN12wxEvtHandler12ProcessEventER7wxEvent+0xb9)[0x2b431c1682c9]
/usr/lib/libwx_gtk2u_core-2.8.so.0(_ZN8wxWindow18GtkSendPaintEventsEv+0x1c7)[0x2b431b7e01b7]
/usr/lib/libwx_gtk2u_core-2.8.so.0[0x2b431b7e06a5]
/usr/lib/libgtk-x11-2.0.so.0[0x2b431cc634df]
/usr/lib/libgobject-2.0.so.0(g_closure_invoke+0x10f)[0x2b431f071b5f]
/usr/lib/libgobject-2.0.so.0[0x2b431f0855ec]
/usr/lib/libgobject-2.0.so.0(g_signal_emit_valist+0x586)[0x2b431f086d16]
/usr/lib/libgobject-2.0.so.0(g_signal_emit+0x83)[0x2b431f0873b3]
/usr/lib/libgtk-x11-2.0.so.0[0x2b431cd6a8f5]
/usr/lib/libgtk-x11-2.0.so.0(gtk_main_do_event+0x48e)[0x2b431cc5d97e]
/usr/lib/libgdk-x11-2.0.so.0[0x2b431d106b94]
/usr/lib/libgdk-
x11-2.0.so.0(gdk_window_process_all_updates+0xd7)[0x2b431d1071b7]
/usr/lib/libgdk-x11-2.0.so.0[0x2b431d1071d9]
/usr/lib/libgdk-x11-2.0.so.0[0x2b431d0ee82e]
/usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x1f2)[0x2b431f8ef0f2]
/usr/lib/libglib-2.0.so.0[0x2b431f8f2396]
/usr/lib/libglib-2.0.so.0(g_main_loop_run+0x1b7)[0x2b431f8f2657]
/usr/lib/libgtk-x11-2.0.so.0(gtk_main+0xa3)[0x2b431cc5db63]
/usr/lib/libwx_gtk2u_core-2.8.so.0(_ZN11wxEventLoop3RunEv+0x6d)[0x2b431b7cd8ed]
/usr/lib/libwx_gtk2u_core-2.8.so.0(_ZN9wxAppBase8MainLoopEv+0x4b)[0x2b431b8619eb]
/usr/lib64/python2.5/site-packages/wx-2.8-gtk2-
unicode/wx/_core_.so(_ZN7wxPyApp8MainLoopEv+0x37)[0x2b431a284137]
unicode/wx/_core_.so[0x2b431a2b5e1e]
menuform.py(PyObject_Call+0x13)[0x417d03]
menuform.py(PyEval_EvalFrameEx+0x4043)[0x486643]
menuform.py(PyEval_EvalCodeEx+0x776)[0x4899d6]
menuform.py[0x4d3c48]
menuform.py[0x41e50f]
menuform.py(PyEval_EvalFrameEx+0x314a)[0x48574a]
menuform.py(PyEval_EvalFrameEx+0x5bd7)[0x4881d7]
menuform.py(PyEval_EvalCode+0x32)[0x489af2]
menuform.py(PyRun_FileExFlags+0x10e)[0x4aaf8e]
menuform.py(PyRun_SimpleFileExFlags+0x1a9)[0x4ab229]
menuform.py(Py_Main+0x8fe)[0x41445e]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b43193741c4]
menuform.py[0x4139d9]
======= Memory map: ========
00400000-0051b000 r-xp 00000000 08:01 28662
/usr/bin/python2.5
0071b000-0074d000 rw-p 0011b000 08:01 28662
/usr/bin/python2.5
0074d000-01e91000 rw-p 0074d000 00:00 0
[heap]
40000000-40001000 ---p 40000000 00:00 0
40001000-40801000 rw-p 40001000 00:00 0
40801000-40802000 ---p 40801000 00:00 0
40802000-41002000 rw-p 40802000 00:00 0
41002000-41003000 ---p 41002000 00:00 0
41003000-41803000 rw-p 41003000 00:00 0
2aaaaaaab000-2aaaaaab2000 r--p 00000000 08:01 31205
/usr/share/locale/pl/LC_MESSAGES/libgnomeui-2.0.mo
2aaaaaab5000-2aaaaab15000 rw-s 00000000 00:08 8093725
/SYSV00000000 (deleted)
2aaaaab15000-2aaaaab1b000 r-xp 00000000 08:01 82154
/usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-xpm.so
2aaaaab1b000-2aaaaad1a000 ---p 00006000 08:01 82154
2aaaaad1a000-2aaaaad1b000 rw-p 00005000 08:01 82154
2aaaaad1b000-2aaaaad26000 r-xp 00000000 08:01 82828
/usr/lib/gtk-2.0/2.10.0/filesystems/libgnome-vfs.so
2aaaaad26000-2aaaaaf26000 ---p 0000b000 08:01 82828
2aaaaaf26000-2aaaaaf27000 rw-p 0000b000 08:01 82828
2aaaaaf27000-2aaaaaf8a000 r-xp 00000000 08:01 30948
/usr/lib/libgnomevfs-2.so.0.2200.0
2aaaaaf8a000-2aaaab189000 ---p 00063000 08:01 30948
2aaaab189000-2aaaab18e000 rw-p 00062000 08:01 30948
2aaaab18e000-2aaaab225000 r-xp 00000000 08:01 31218
/usr/lib/libgnomeui-2.so.0.2000.1
2aaaab225000-2aaaab424000 ---p 00097000 08:01 31218
2aaaab424000-2aaaab42a000 rw-p 00096000 08:01 31218
2aaaab42a000-2aaaab462000 r-xp 00000000 08:01 30805
/usr/lib/libgconf-2.so.4.1.5
2aaaab462000-2aaaab662000 ---p 00038000 08:01 30805
2aaaab662000-2aaaab667000 rw-p 00038000 08:01 30805
2aaaab667000-2aaaab687000 r-xp 00000000 08:01 228103
/usr/lib/libdbus-glib-1.so.2.1.0
2aaaab687000-2aaaab886000 ---p 00020000 08:01 228103
2aaaab886000-2aaaab888000 rw-p 0001f000 08:01 228103
2aaaab888000-2aaaab8c3000 r-xp 00000000 08:01 28469
/usr/lib/libdbus-1.so.3.4.0
2aaaab8c3000-2aaaabac2000 ---p 0003b000 08:01 28469
2aaaabac2000-2aaaabac4000 rw-p 0003a000 08:01 28469
2aaaabac4000-2aaaabb42000 r-xp 00000000 08:01 26956
/usr/lib/libgnutls.so.26.1.6
2aaaabb42000-2aaaabd42000 ---p 0007e000 08:01 26956
2aaaabd42000-2aaaabd4d000 rw-p 0007e000 08:01 26956
2aaaabd4d000-2aaaabd50000 r-xp 00000000 08:01 30822
/usr/lib/libavahi-glib.so.1.0.1
2aaaabd50000-2aaaabf4f000 ---p 00003000 08:01 30822
2aaaabf4f000-2aaaabf50000 rw-p 00002000 08:01 30822
2aaaabf50000-2aaaabf5c000 r-xp 00000000 08:01 28467
/usr/lib/libavahi-common.so.3.5.0
2aaaabf5c000-2aaaac15b000 ---p 0000c000 08:01 28467
2aaaac15b000-2aaaac15c000 rw-p 0000b000 08:01 28467
2aaaac15c000-2aaaac16c000 r-xp 00000000 08:01 28471
/usr/lib/libavahi-client.so.3.2.4
2aaaac16c000-2aaaac36b000 ---p 00010000 08:01 28471
2aaaac36b000-2aaaac36c000 rw-p 0000f000 08:01 28471
2aaaac36c000-2aaaac37d000 r--s 00000000 08:01 43898
/usr/share/mime/mime.cache
2aaaac385000-2aaaac395000 r-xp 00000000 08:01 333924
/lib/libresolv-2.7.so
2aaaac395000-2aaaac595000 ---p 00010000 08:01 333924
2aaaac595000-2aaaac597000 rw-p 00010000 08:01 333924
2aaaac597000-2aaaac599000 rw-p 2aaaac597000 00:00 0
2aaaac599000-2aaaac603000 r-xp 00000000 08:01 31161
/usr/lib/libbonoboui-2.so.0.0.0
2aaaac603000-2aaaac802000 ---p 0006a000 08:01 31161
2aaaac802000-2aaaac807000 rw-p 00069000 08:01 31161
2a
Ticket URL: <http://trac.osgeo.org/grass/ticket/201>
