GDAL
July 9, 2013, 11:12am
1
#2026: v.surf.rst window too wide
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
There's a bug in automatic module window generation as it generates
v.surf.rst window too wide - it's wider than 1440px (my monitor horizontal
resolution) and it's not possible to make window more narrow, only wider.
GRASS SVN Revision: 56987M
wxPython: 2.9.4.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
July 9, 2013, 2:24pm
2
Cpu: Unspecified |
Comment(by neteler):
This must be a wxPython 2.9 bug?
GRASS 7.0.svn (nc_spm_08_grass7):~ > v.surf.rst &
GRASS 7.0.svn (nc_spm_08_grass7):~ > xwininfo
xwininfo: Window id: 0x6200072 "v.surf.rst [vector, surface,
interpolation, 3D]"
Width: 620
Height: 500
GRASS 7.0.svn (nc_spm_08_grass7):~ > wx-config --version
2.8.12
GRASS 7.0.svn (nc_spm_08_grass7):~ > g.version -g
version=7.0.svn
date=2013
revision=57044M
build_date=2013-06-09
No such problem on Fedora 18.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026#comment:1> ;
GDAL
March 28, 2014, 8:06pm
3
Cpu: Unspecified |
Comment(by annakrat):
It should be fixed in r59497. Please test (tests on other platforms are
needed too). It affected many other modules which has long description.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026#comment:2> ;
GDAL
June 3, 2014, 10:35am
4
Cpu: Unspecified |
Comment(by marisn):
Seems to be fixed.
Tested with: GRASS version: 7.1.svn GRASS SVN Revision: 60684M wxPython:
3.0.0.0
Needs backporting to 7.0 ? Leaving open.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026#comment:3> ;
GDAL
June 3, 2014, 1:41pm
5
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: Linux | Cpu: Unspecified
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 marisn]:
> Seems to be fixed.
3.0.0.0
I realized that the change didn't work well on Windows, so I tried to fix
that in r60689. Everything is backported in r60690.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026#comment:4> ;
GDAL
May 26, 2015, 1:13pm
6
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
I'm getting this same bug in 6.4.5RC1. Is it possible to backport the
solution ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2026#comment:5> ;
GDAL
May 29, 2015, 8:20pm
7
Comment (by annakrat):
Backported in r65341.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2026#comment:6> ;
