#2045: r.to.vect: use less memory
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect
Comment (by mlennert):
Replying to [comment:20 mmetz]:
> Replying to [comment:19 mlennert]:
> > Data and info provided via private mail.
> I have received the data, thanks!
> > Previous posters have also reported that setting GRASS_VECTOR_LOWMEM
didn't make much of a difference, so maybe the problem is there ?
> I don't think so. Without GRASS_VECTOR_LOWMEM, v.build needs about 26 GB
of RAM. With GRASS_VECTOR_LOWMEM, v.build needs about 11 GB of RAM but is
about 4.5 times slower, that is expected because some temporary data are
kept on disk and not in memory.
Why does it still need 11GB of RAM when working with disk-based data ? Is
this really unavoidable ?
GRASS has always had a tradition of allowing to work on limited resources.
Even though RAM is cheap, I would still consider > 11GB as rather high-end
in many offices. I wouldn't mind if it makes the command much slower, but
it would be nice if it could get the job done with less RAM usage...
But I have nothing to propose, so I'll leave it at that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:21>
