[GRASS-dev] [GRASS GIS] #2072: Trouble loading workspace.gxw
Reporter: richardc | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: | Platform: Linux
      Cpu: x86-32 |
I'm unable to load the workspace.gxw file in GRASS 7 (57592)
I receive the following error:
Reading workspace file </home/user/RESEARCH/workspace_ ..GRASS7nviz.gxw>
failed.
Invalid file, unable to parse XML document.
Reason: invalid literal for int() with base 10: '7000.0'
   File "/home/user/grass7/grass7_trunk/dist.i686-pc-linux-
gnu/etc/gui/wxpython/lmgr/frame.py", line 1113, in LoadWorkspaceFile
     gxwXml = ProcessWorkspaceFile(etree.parse(filename))
gnu/etc/gui/wxpython/core/workspace.py", line 58, in __init__
     self.__processFile()
gnu/etc/gui/wxpython/core/workspace.py", line 149, in __processFile
     self.__processLayers(display)
gnu/etc/gui/wxpython/core/workspace.py", line 176, in __processLayers
     cmd, selected, vdigit, nviz = self.__processLayer(item)
gnu/etc/gui/wxpython/core/workspace.py", line 238, in __processLayer
     nviz = self.__processLayerNviz(node_nviz)
gnu/etc/gui/wxpython/core/workspace.py", line 378, in __processLayerNviz
     nviz['vector']['points'])
gnu/etc/gui/wxpython/core/workspace.py", line 443, in
__processLayerNvizNode
     value = cast(self.__getNodeText(node_tag, 'value'))
ValueError: invalid literal for int() with base 10: '7000.0'
After deleting the following, the 'Please wait, loading workspace' notice
remains visible and layers are not loaded into the 3Dview.
  <size>
<value>7000.0</value>
</size>
I also notice in the command console, not sure if relevant:
Loading raster map
<srtm_cgiar_mosaic2_cp_int16@PERMANENT>...
Translating colors from raster map
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072&gt;
#2072: Unable to load workspace.gxw in 3D View
      Cpu: x86-32 |
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072#comment:1&gt;
      Cpu: x86-32 |
Description changed by martinl:
Old description:
failed.
<size>
</size>
Loading raster map
New description:
failed.
  <size>
</size>
Loading raster map
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072#comment:2&gt;
Keywords: nviz, workspace | Platform: Linux
      Cpu: x86-32 |
Changes (by martinl):
  * keywords: => nviz, workspace
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072#comment:3&gt;
      Cpu: x86-32 |
Comment(by annakrat):
Should be fixed in r57624 (backported in r57626,7).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2072#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: nviz, workspace
  Platform: Linux | Cpu: x86-32
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2072#comment:5&gt;
