[GRASS-dev] [GRASS GIS] #2090: r.reclass.area - added flag to indicate input map is pre-clumped
Reporter: egoddard | Owner: grass-dev@…
Component: Raster | Version: svn-trunk
Keywords: reclass, clump | Platform: Unspecified
      Cpu: All |
Added a flag (-c) to r.reclass.area.py to indicate that the input map is
pre-clumped. This is useful for using r.reclass.area with clump maps
generated from other tools such as r.clump4p
(http://sil.uc.edu/downloads.html#software) that can drastically reduce
processing time.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2090&gt;
      Cpu: All |
Comment(by neteler):
Some issues have been pointed out in r.clump4p:
http://lists.osgeo.org/pipermail/grass-dev/2014-February/067484.html
Would your patch work also with stock r.clump?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2090#comment:1&gt;
      Cpu: All |
Comment(by egoddard):
Yes, the flag just indicates the input map is already clumped so that it
will skip the clumping phase of r.reclass.area. It doesn't matter which
algorithm is used to do the clumping.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2090#comment:2&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: reclass, clump
  Platform: Unspecified | Cpu: All
Changes (by lucadelu):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 egoddard]:
I have applied the patch in r59376.
Thanks closing the ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2090#comment:3&gt;
