#2120: wxgui: encoding errors
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-releasebranch64
Keywords: locale encoding | Platform: Unspecified
Cpu: Unspecified |
Using grass64release in French (locale: fr_BE.utf8), I seem to be seeing
more encoding errors than before in the wxGUI. Examples are when running
v.in.ogr, r.in.gdal, v.build. In fact whenever a module emits a message in
the locale's language which contains special characters, I get errors such
as
'ascii' codec can't decode byte 0xef in position 16: ordinal
not in range(128)
I don't get such errors on the command line.
These errors do not keep the module from functioning, but it makes reading
its messages nearly impossible unless you really know what to look for.
I don't have the time now to go back and try to find out if this worked
better before, but I do think so. It might just be that more strings have
been translated to French and that is why I see these errors now.
I think this also adds to the recent discussions about test in that it
makes it evident that if we want to take multi-locale usage of GRASS
seriously, we probably need to think of a series of tests that developers
should use to make sure any changes do not create such encoding problems.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2120>
