[GRASS-dev] [GRASS GIS] #2121: v.rast.stats: allow choice of statistics
Reporter: mlennert | Owner: grass-dev@…
Component: Vector | Version: svn-trunk
Keywords: v.rast.stats | Platform: Unspecified
      Cpu: Unspecified |
It would be convenient if v.rast.stats allowed a choice of statistics that
one wants to upload to the attribute table. Currently, it creates 9
columns:
INTEGER|B5_n
DOUBLE PRECISION|B5_min
DOUBLE PRECISION|B5_max
DOUBLE PRECISION|B5_range
DOUBLE PRECISION|B5_mean
DOUBLE PRECISION|B5_stddev
DOUBLE PRECISION|B5_varianc
DOUBLE PRECISION|B5_cf_var
DOUBLE PRECISION|B5_sum
a series of which can actually be derived from others (mean, range, sttdev
|| variance, coefficient of variation), meaning that only 5 are really
needed (n, min, max, variance || stddev, sum).
So, at least we could limit the uploaded statistics to those 5, or even
allow choice of statistics through a parameter.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Trac didn't like my use of the pipe character as OR operator, so "variance
stddev" should read "variance OR stddev".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:1&gt;
      Cpu: Unspecified |
Comment(by lucadelu):
I added a ''method'' option to choose the methods to save in the attribute
table in r58726.
I would like also to remove ''-e'' flag and add the methods calculated by
extended statistics to the ''method'' 's options, what do you think?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:2&gt;
      Cpu: Unspecified |
Replying to [comment:2 lucadelu]:
attribute table in r58726.
by extended statistics to the ''method'' 's options, what do you think?
Please try r58727, in previous version there was a small bug.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:3&gt;
      Cpu: Unspecified |
This is great, thanks ! Just one problem: it fails at lines 255-256 with
the dbf driver as colnames get truncated, but your variable names are
full, and so
variable = colname.replace("%s_" % colprefix, '')
i = variables[variable]
leads to a key error since 'variable' does not exist in 'variables'. A
solution might be to use a dictionary linking variable names to colnames ?
Sounds reasonable to me.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 mlennert]:
full, and so
Yes I fixed it using dictionary, try r58728 (it also solve another problem
with DBF driver).
I wait other dev's comments before make these changes
> Moritz
Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:5&gt;
      Cpu: Unspecified |
Replying to [comment:5 lucadelu]:
with the dbf driver as colnames get truncated, but your variable names are
full, and so
Yup, works great now.
> (it also solve another problem with DBF driver).
Great, I had just stumbled upon that while testing !
Now, one more issue: since recently (r57999), there is the possibility to
abbreviate option values, but this does not seem to work here:
v.rast.stats blks raster=elevation column=elev
method=mini,maxi,mean,stddev -c
Processing data (2535 categories)...
   File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-
linux-gnu/scripts/v.rast.stats", line 295, in <module>
     main()
linux-gnu/scripts/v.rast.stats", line 261, in main
KeyError: 'mini'
I don't know exactly what's needed to make this work, but it would be nice
if it did.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:6&gt;
      Cpu: Unspecified |
Comment(by matmar):
Hi Moritz,
> Moritz
I would preserve the (singol) choice of all the 9 statistics without
dropping the extended ones.
Furthermore, just a suggestion: the "average" statistic is called
"average" in r.series and "mean" in v.rast.stats. It would be great if
someone could manage to unify the terminology...
Matteo
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:7&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:7 matmar]:
> called "average" in r.series and "mean" in v.rast.stats.
> It would be great if someone could manage to unify the terminology...
Right. For a discussion on this, see this email and following:
http://lists.osgeo.org/pipermail/grass-dev/2013-October/thread.html#65948
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:8&gt;
      Cpu: Unspecified |
Replying to [comment:6 mlennert]:
to abbreviate option values, but this does not seem to work here:
> main()
> KeyError: 'mini'
nice if it did.
fixed in r58731, I just check the long name and set it instead the
abbreviate one.
No objections were done for remove the ''e'' flag and add the methods to
''method'' option, so I start to implement it
> Moritz
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:9&gt;
      Cpu: Unspecified |
fixed in r58731.
> Matteo
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:10&gt;
      Cpu: Unspecified |
Replying to [comment:10 lucadelu]:
> fixed in r58731.
Actually AFAIK, there was no agreement, yet, on what was preferred. Vaclav
actually argued for 'mean' instead of 'average'
[http://lists.osgeo.org/pipermail/grass-dev/2013-October/065977.html 1].
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:11&gt;
      Cpu: Unspecified |
Replying to [comment:9 lucadelu]:
> > main()
> > KeyError: 'mini'
nice if it did.
abbreviate one.
Seems to work nicely, thanks !
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:12&gt;
      Cpu: Unspecified |
Please try r58735, it remove 'e' flag and add the extended methods to the
new 'method' option.
Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:13&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.rast.stats
  Platform: Unspecified | Cpu: Unspecified
Changes (by lucadelu):
  * status: new => closed
  * resolution: => fixed
Comment:
Ticket completed, closing it.
Please reopen if needed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2121#comment:14&gt;
