#2135: wxGUI: failed to show legend when PIL is missing
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: legend, PIL | Platform: Linux
Cpu: x86-64 |
It's not possible to show legend when PIL package is not available, see
traceback bellow
File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/mapdisp/frame.py", line 187, in <lambda>
overlay.overlayChanged.connect(lambda:
self.MapWindow2D.UpdateMap(render=False, renderVector=False))
gnu/etc/gui/wxpython/mapwin/buffered.py", line 720, in UpdateMap
for img in self.GetOverlay():
gnu/etc/gui/wxpython/mapwin/buffered.py", line 601, in GetOverlay
img = utils.autoCropImageFromFile(overlay.mapfile)
gnu/etc/gui/wxpython/core/utils.py", line 1103, in autoCropImageFromFile
from PIL import Image
Cpu: x86-64 |
Comment(by annakrat):
I added special handling of missing PIL in r58256 (with advice to install
it), however we should decide if PIL is a official requirement for wxGUI.
Now it's used for cropping overlays (legend and so) so that you can move
more decorations easily.
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:1 annakrat]:
> wxGUI.Now it's used for cropping overlays (legend and so) so
> that you can move more decorations easily.
fwiw it is already "encouraged", since if PIL is there the wxGUI PsMap and
Animation tools like to use it too.
Cpu: x86-64 |
Replying to [comment:2 hamish]:
and Animation tools like to use it too.
Animation tool uses PIL for the same reason as map Window now - trim
legend so that you can move it around the screen easily.
