#2144: winGRASS6.4.svn - GUI problems with postgres as database backend
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: wxGUI | Version: svn-releasebranch64
Keywords: wingrass, database, postgres, wxgio | Platform: MSWindows 7
Cpu: x86-64 |
tested with
System Info
GRASS Version: 6.4.4svn
GRASS SVN Revision: 58440
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.1
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
postgresql-9.3.2-1-windows-x64
nc_spm_08
(1)
new database in postgres by pgAdminIII: grassgisdb
(2)
new mapset in nc_spm_08: pgtest
(3)
db.connect --verbose driver=pg database=host=localhost,dbname=grassgisdb
(4)
db.login --verbose driver=pg database=host=localhost,dbname=grassgisdb
user=xxxxxxx password=xxxxxx
(5)
db.connect -p
driver:pg
database:host=localhost,dbname=grassgisdb
schema:
group:
(6)
g.copy --verbose vect=firestations@PERMANENT,firestationspg
Copy vector <firestations@PERMANENT> to current mapset as <firestationspg>
(7)
g.list type=vect
vector Dateien im Mapset <pgtest> vorhanden:
firestationspg
check by pgAdminIII: the attribute table of firestationspg is in the
postgres-database grassgisdb
(8)
db.tables-wxgui
db.tables -p --verbose
information_schema.sql_features
information_schema.sql_implementation_info
information_schema.sql_languages
information_schema.sql_packages
information_schema.sql_parts
information_schema.sql_sizing
information_schema.sql_sizing_profiles
(9)
db.columns-wxgui: no firestationspg attribute table choosable, only table
mentioned in (8)
(10)
d.vect map=firestationspg@pgtest
vector points are displayed in map display
(11)
v.db.addcol --quiet map=firestationspg@pgtest columns=hk int
(Sun Dec 15 01:36:14 2013) Befehl ausgeführt (4 Sek)
(Sun Dec 15 01:38:32 2013)
v.db.addcol --verbose map=firestationspg@pgtest columns=hk2 int
(Sun Dec 15 01:38:35 2013) Befehl ausgeführt (3 Sek)
columns are added
(12)
v.db.update-wxgui
v.db.update map=firestationspg@pgtest column=<required>
columns added by (11) aren't choosable in the v.db.update-wxgui
(13)
v.db.update by command line ok
v.db.update map=firestationspg@pgtest column=hk value=1
(Sun Dec 15 01:42:17 2013) Befehl ausgeführt (5 Sek)
(Sun Dec 15 01:42:44 2013)
v.db.update --verbose map=firestationspg@pgtest column=hk2 value=1
SQL: "UPDATE firestationspg SET hk2=1"
(Sun Dec 15 01:42:47 2013) Befehl ausgeführt (3 Sek)
(14)
v.db.dropcol-wxgui
v.db.dropcol map=firestationspg@pgtest column=<required>
columns added by (11) aren't choosable in the v.db.dropcol-wxgui
(15)
v.db.dropcol --verbose map=firestationspg@pgtest column=hk2
(Sun Dec 15 01:47:24 2013) Befehl ausgeführt (3 Sek)
(16)
map query a point of firestationspg in map display => wingrass6.4.4svn
crashes, not only gui, also whole session
(17)
open attribute table of firestationspg by right click => wingrass6.4.4svn
summary:
(A) postgres as database backend '''is''' working with actions from the
(wxgui)command console in wingrass6.4.4svn
(B) postgres as database backend '''is not''' working within the wxgui of
different actions (attribute table manager, map query, v.db.dropcol-wxgui,
etc.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2144>
