[GRASS-dev] [GRASS GIS] #2172: g.remove takes too long to remove vector on Windows
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: g.remove | Platform: MSWindows 7
      Cpu: x86-64 |
I am having troubles with removing vector maps on Windows. It just takes
much more time than it should (I am talking about several minutes for
simple vector map). It looks like it gets stuck on removing a temporary
directory which is empty when I looked into it during g.remove run. That's
the last debug output and after it, it doesn't seem to do anything but
after 2 minutes or so, the command finishes successfully.
D3/5: remove directory 'C:\Users\akratoc\grassdata/nc_basic_
spm_grass7/user1/.tmp/unknown/3960.0'
It does not matter if there is any table connected or not. The problem
appears whenever I run a vector module with --o and the vector map exists,
of course.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2172&gt;
      Cpu: x86-64 |
Comment(by annakrat):
I am still having this issue, even after OS changed to Windows 8.
Moreover, I saw this happening on one other Windows 8 computer.
Yesterday, I realized a similar behavior when working with mask,
specifically when creating inverse mask during clean up when g.remove is
called
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/r.mask/r.mask.py#L76
Debug output showed that some of the files of the raster were removed but
then it was waiting for a minute or so to delete the rest. I repeated it
several times, some times it went through without problems sometimes it
took too long. I have never had problems with deleting rasters before.
This is really frustrating. Anyone has any idea what would be the possible
cause of this? Or has anyone experienced this behavior?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2172#comment:1&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:1 annakrat]:
> Anyone has any idea what would be the possible cause of this?
One possible cause is the file being opened by processes which monitor the
filesystem, such as Windows' indexing service, virus scanners,
TortoiseSVN, etc.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2172#comment:2&gt;
