r.li.shannon (and consequently r.li.pielou) returns the wrong output when
"Whole Maplayer / Select areas from the overlayed vector map" option is
used to build the configuration file. I attached everything's needed to
replicate the error (with r.li.shannon).
Replying to [ticket:2180 matmar]:
when "Whole Maplayer / Select areas from the overlayed vector map" option
is used to build the configuration file.
r.li.shannon as well as related modules (dominance, pielou, renyi,
simpson) are fixed in trunk r59072.
Replying to [comment:2 mmetz]:
After more testing and bugfixing with matmar, the r.li modules seem to be
stable in G7: no more crashes, and the results are in our tests correct.
While the r.li.setup replacement in G7 is still work in progress,
r.li.setup in G6 works, but all other r.li modules in G6 must be
considered as not functional. With luck, they don't crash, and with even
more luck, the result is correct, but most likely it is not.
