#2185: Painfully Slow 'v.in.ogr' Vector Import
Reporter: justinzane | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Vector | Version: svn-trunk
Resolution: | Keywords: import, OGR, performance, v.in.ogr
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:37 hcho]:
> Yes, that's what I found too. Vect_line_intersection2 doesn't have this
issue, but it still creates a single point intersection at the first
vertex of the second new line (line ID 3) in the geojson example.
> Line ID 1: original unbroken line
> 1st iteration
> Line ID 2-4: new broken lines
> 2nd iteration
> Line ID 5: identical to line 3
> Line ID 6: start node of line 3
> Lines 5 & 6 shouldn't be returned at all from the intersection routine,
I think. The patch fixes this.
I found another issue in Vect_segment_intersection(): the order of the
segments matters, i.e. the intersection point of a with b can be slightly
different from the intersection point of b with a. The second attached
patch fixes that and also avoids that infinite loop. I opt to apply both
patches.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2185#comment:38>
