[GRASS-dev] [GRASS GIS] #22: Grass r.out.mat 64bit Matlab reading problem
Reporter: alexice | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.3.0
Component: default | Version: 6.2.3
Keywords: |
Grass raster maps which are exported with r.out.mat in an 64bit
environment can not be read into Matlab (2007a). If I transfer the grass
database to my 32bit laptop and export it there, it works and can be read
by the same Matlab version.
If any more information is needed, please contact me.
Alexice
Ticket URL: <http://trac.osgeo.org/grass/ticket/22&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by hamish):
Hi Alexice,
I am not too surprised at hearing that.
raster/r.out.mat/main.c:
The mrows, ncols, format_block, and realflag variables are type "long" and
written with fwrite(...,sizeof(long),...);. They should be written as 4
bytes on all platforms. The name_len variable too.
I think it's an easy fix but I have only passing exposure to 64bit
programming. I don't have a 64bit machine to test on, but I do have matlab
2007a.
r.in.mat uses fread() + "long" integers for those things too, so would
need to be fixed as well.
thanks for the report,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:1&gt;
Comment (by 1gray):
Replying to [comment:1 hamish]:
and written with fwrite(...,sizeof(long),...);. They should be written as
4 bytes on all platforms. The name_len variable too.
         The file should `#include <stdint.h>' and use int32_t instead of
`long' where the bit width is important.
2007a.
         At the very least, the s/long/int32_t/ change (where appropriate)
shouldn't break the 32-bit build. Could you check it? (I have access to
a 64-bit host, but not to Matlab.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:2&gt;
Comment (by glynn):
stdint.h and int32_t are C99, and shouldn't be used in GRASS.
The correct solution is to explicitly [de]serialise values rather than
reading/writing the in-memory representation directly from/to files.
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:3&gt;
Comment (by alexice):
Since I have Matlab (R2007a) and a 64bit machine at hand, please let me
know if I can test some versions of the r.out.mat and r.in.mat functions.
No problem for me.
alexice
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:4&gt;
Comment (by 1gray):
Replying to [comment:3 glynn]:
I stand corrected.
I was about to suggest using Gnulib-provided {{{stdint.h}}} (since Gnulib
is ''not'' a dependency, please check [http://www.gnu.org/software/gnulib/
here]), but won't the explicit [de]serialisation also solve endianness
issues, if any?
BTW, shouldn't the other modules also be checked for similar issues?
These [de]serialization routines are, to my mind, good candidates to
inclusion into the library.
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:5&gt;
Glynn:
> than reading/writing the in-memory representation directly from/to
> files.
If anyone wants to write a patch, feel free.
1grey:
> issues, if any?
r.in|out.mat's endian code is in a only-just-working state. As the
endianness of the file's data is stored in one of the header bits I
propose we follow one of Glynn's earlier suggestions and just force
r.out.mat to always produce little endian output regardless of platform
instead of dynamically picking what to use based on the current platform.
With Mac moving to intel this is less of an issue, but since we know it's
a problem we might as well take the opportunity to fix that too.
1gray:
> issues? These [de]serialization routines are, to my mind, good
> candidates to inclusion into the library.
r.in|out.bin is the main one to worry about. I am not sure but hopefully
r.*.gdal and v.*.ogr 64bit+endian stuff is all handled upstream in the
(well maintained) support libraries.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:6&gt;
Glynn wrote on grass-dev ml:
> Actually, I would suggest using big-endian format. That way, if
> someone writes code which ignores byte order (i.e. just read
> directly into memory), you discover it sooner rather than later.
> [On a related issue, the UK is at a disadvantage when it comes to
> writing code which deals with timezones. If you confuse GMT and
> local time, you won't notice until daylight-saving time starts.]
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:7&gt;
Glynn:
> files.
1grey:
> issues, if any?
someone writes code which ignores byte order (i.e. just read directly
writing code which deals with timezones. If you confuse GMT and local
Comment (by glynn):
Replying to [comment:6 hamish]:
> > files.
For now, I've simply replaced "long" with "int", as the latter will be 32
bits on nearly all systems.
That should fix the 64-bit problems, but it won't do anything about byte
order.
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:8&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
Thanks Glynn.
Tested* and backported to the 6.3.0 branch.
[*] tested on a 32-bit system, before/after output files are binary equal.
making the two modules big-endian safe is a well documented TODO, so no
need to keep this bug report open for that; closing it.
I'd still like to hear feedback from a 64bit user confirming that
everything works now.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:9&gt;
ps- for doing the little to big-endian conversion see the commented out
code at the end of the r.in.mat/main.c. SwabShort(), SwabLong(),
SwabFloat(), SwabDouble()
H
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:10&gt;
Comment (by neteler):
I have uploaded the exported Spearfish roads raster map, exported on 64bit
Linux box (Mandriva 2008.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:11&gt;
Resolution: fixed | Keywords: r.out.mat endian
  * keywords: => r.out.mat endian
Comment:
Replying to [comment:11 neteler]:
64bit Linux
I will test the file, but I think this is solved. Specifically the 64 bit
error should be solved by:
Glynn:
32 bits
order.
and thus this bug (wrt 64bit) is closed.
A remaining problem is to fix the endian stuff.
or do you experience something else?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:12&gt;
Resolution: fixed | Keywords: r.out.mat 64bit
  * keywords: r.out.mat endian => r.out.mat 64bit
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:13&gt;
> exported on 64bit Linux box (Mandriva 2008.0).
the file is binary equal to the same made on a 32bit machine and imports
fine into matlab 2007a and octave.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:14&gt;
