#2228: g.mremove: add an option to use 'map name exclusion patterns' like is
available in g.mlist
Reporter: pvanbosgeo | Owner: grass-dev@…
Component: Default | Version: svn-trunk
Keywords: g.mlist, g.list, g.mremove, g.mremove, interface | Platform: All
Cpu: All |
Changes (by wenzeslaus):
* keywords: => g.mlist, g.list, g.mremove, g.mremove, interface
Comment:
I'm not able to inspect the patch but I tried to write a basic test for
it. See the attachment. You can run it inside a sample NC location in
user1 mapset using:
python test_g_mremove.py --verbose
Feel free to contribute more test cases if you have ideas.
Also, I just noticed that Luca actually wanted the g.mremove interface for
g.mlist and for a moment I though I too but than I remembered that this
this was already discussed on grass-dev with a clear result, so adding the
main points here too.
[http://lists.osgeo.org/pipermail/grass-dev/2014-May/068595.html
g.mremove: adding 'map name exclusion pattern' option] (Huidae Cho):
The g.mremove interface looks convenient, but can be dangerous...
...deleted my raster files by using the
positional parameter thing while trying to delete all my temporary
vectors.
g.mremove tmp*
Did I want to delete tmp* rasters or vectors? I forgot to add vect=
and my tmp* rasters were listed. Thanks to the -f option.
... Also, if we want
to add the exclude= parameter to g.mremove, it's not just one but 12
because there are 12 data types and pattern parameters...
[http://lists.osgeo.org/pipermail/grass-dev/2008-October/040506.html
g.mlist syntax vs g.mremove syntax] (Glynn Clements):
...it's g.mremove (and g.remove, g.copy, g.rename)
which got it wrong. I'm aware that having a separate option for each
type means less typing, but...
the g.list/g.mlist interface makes for a smaller (and arguably
simpler) GUI dialog.
...g.mremove interface is basically a fudge to get
around the restriction that the parser only allows a single
"positional" parameter, and requires keywords for the rest. You can't
just use e.g.:
g.mlist rast gpcp_1dd_p1d.*.*
but you can "fudge" it to:
g.mlist rast=gpcp_1dd_p1d.*.*
by having a separate option for each type.
...using separate options means...
multiple remove/rename/copy operations in a single command. But I
wouldn't expect that usage to be particularly common...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2228#comment:6>
