[GRASS-dev] [GRASS GIS] #2279: wingrass71: rendering problems with raster layers automatically added by finished
finished
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wingrass, rendering | Platform: MSWindows 7
      Cpu: x86-64 |
taken from the dev-ML
http://lists.osgeo.org/pipermail/grass-dev/2014-May/068633.html
tested with winGRASS71 by osgeo4w from today.
Rendering is activated in map display.
start e.g. r.slope.aspect in the wxgui, define more than one outputs.
Automatically adding the results to map display is activated.
run r.slope.aspect, after the output results are added to map display,
rendering has problems.
-erase map display erases display, but rendering again raster artefacts
are
displayed
- change raster color, raster artefacts are displayed
-only after deleting from and readding result raster in map display,
rendering is correct.
anyone confirms this behavior?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279&gt;
finished
      Cpu: x86-64 |
Comment(by hellik):
tested with
GRASS Version: 7.1.svn
GRASS SVN Revision: 60050
Erstellungsdatum: 2014-05-03
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:1&gt;
finished
      Cpu: x86-64 |
Comment(by hellik):
screenshots with rendering artefacts added.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:2&gt;
finished modules
      Cpu: x86-64 |
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:3&gt;
finished modules
      Cpu: x86-64 |
Comment(by annakrat):
By artifacts you mean that you see different layers in map display and in
the layer manager? I had no problems with this on Ubuntu, I will try it on
Windows tomorrow.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:4&gt;
finished modules
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 annakrat]:
in the layer manager? I had no problems with this on Ubuntu, I will try it
on Windows tomorrow.
have a look at the screenshots. this blue raster layer is the artefact.
this remains/persists although you toggle on/ off the several resultat
output maps automatically added to the map display by a finished module
like r.slope.aspect. it remains also if you zoom in/out.
only manually removing and adding again to map display helps.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:5&gt;
finished modules
      Cpu: x86-64 |
Replying to [comment:5 hellik]:
no, toggle no/off worked for me, otherwise I can confirm it. It basically
doesn't show that the layer is checked when it is checked. I will try to
look at it this week.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:6&gt;
finished modules
      Cpu: x86-64 |
Please try r60131. This was a side effect from r58939.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:7&gt;
finished modules
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, rendering
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:7 annakrat]:
tested with
GRASS SVN Revision: 60138
Erstellungsdatum: 2014-05-07
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
it works now, closing ticket.
thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:8&gt;
finished modules
Comment(by martinl):
Replying to [comment:8 hellik]:
no need for backport to relbr70?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:9&gt;
finished modules
Comment(by hellik):
Replying to [comment:9 martinl]:
ah, for sure. reopened ticket until backport.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:10&gt;
finished modules
      Type: defect | Status: reopened
Resolution: | Keywords: wingrass, rendering
Changes (by martinl):
  * status: closed => reopened
  * resolution: fixed =>
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:11&gt;
finished modules
Changes (by annakrat):
  * status: reopened => closed
Comment:
Backported in r60145.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:12&gt;
