GDAL
May 5, 2014, 9:39pm
1
#2283: wingrass: failure when loading addons
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Addons | Version: svn-trunk
Keywords: wingrass, launch | Platform: MSWindows 2K
Cpu: Unspecified |
WinGRASS currently fails with not understandable error message attachment
:addons-error.png when installed addons are incompatible with launched
GRASS. Some better error tracking is needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
July 17, 2014, 8:47pm
2
Cpu: Unspecified |
Comment(by wenzeslaus):
Can you please elaborate more on how the addons are handled and what
actually went wrong? I tis not clear to me if this is something which
happens all the time or just when there is error in the source code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:1> ;
GDAL
July 30, 2014, 7:47am
3
Priority: critical | Milestone: 7.0.0
Cpu: Unspecified |
Changes (by martinl):
* priority: blocker => critical
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:2> ;
GDAL
October 24, 2014, 8:05am
4
Cpu: Unspecified |
Comment(by neteler):
Is this still an issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:3> ;
GDAL
October 24, 2014, 9:43am
5
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:3 neteler]:
yes
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:4> ;
GDAL
December 27, 2014, 3:02pm
6
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:1 wenzeslaus]:
the failure comes up if you have installed a binary addon (e.g.
r.geomorphon) built upon an another winGRASS version (e.g. winGRASS7beta1)
and you try now to use it with another/newer version (e.g. winGRASS7beta3
or winGRASS trunk).
the error message should contain something like: "you are trying to use an
addon built upon an another/older version of winGRASS; please update your
addon by reinstalling".
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:5> ;
GDAL
December 27, 2014, 3:11pm
7
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:5 hellik]:
an addon built upon an another/older version of winGRASS; please update
your addon by reinstalling".
I've seen that in C:\Users\xxxxx\AppData\Roaming\GRASS7\addons\modules.xml
there is following entry:
<libgis revision="62177" />
using this information for a wxGUI-startup message which indicates to a
needed addon update?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:6> ;
GDAL
February 14, 2015, 5:14pm
8
Cpu: Unspecified |
Perhaps the issue got now solved in r64581?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:7> ;
GDAL
February 14, 2015, 5:22pm
9
Cpu: Unspecified |
Replying to [comment:6 hellik]:
> I've seen that in
C:\Users\xxxxx\AppData\Roaming\GRASS7\addons\modules.xml there is
following entry:
yes, I was thinking about that, but it's not implemented yet.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:8> ;
GDAL
February 14, 2015, 5:23pm
10
Cpu: Unspecified |
Replying to [comment:7 neteler]:
no, loading addons by wxGUI on start has been disabled in r64533. But not
yet backported.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:9> ;
GDAL
February 14, 2015, 5:27pm
11
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:9 martinl]:
not yet backported.
I was just looking at it, do you plan to backport first the ones (r64499,
r64504, r64532) listed on the wiki? r64533 will be easier to backport
then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:10> ;
GDAL
February 14, 2015, 5:38pm
12
Priority: minor | Milestone: 7.0.0
Cpu: Unspecified |
Changes (by annakrat):
* priority: critical => minor
Comment:
Everything related to this seems to backported (r64628, r64629). I am
downgrading this ticket because it would be still nice to be able to know
if addons are compatible or not.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:11> ;
