[GRASS-dev] [GRASS GIS] #2320: PyGRASS doesn't write 3D vector map
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Component: Python | Version: svn-trunk
Keywords: pygrass | Platform: All
      Cpu: Unspecified |
When I create a new vector using PyGRASS, create 3D points and write them
to the map, v.info says the map is 2D. The problem is that PyGRASS doesn't
specify anywhere that the map should be 3D. The following change works for
me but I am not completely sure it's correct:
Index: pygrass/vector/__init__.py
--- pygrass/vector/__init__.py (revision 60631)
+++ pygrass/vector/__init__.py (working copy)
@@ -187,6 +187,12 @@
          if geo_obj.gtype == _Area.gtype:
              result = self._write_area(geo_obj)
+ if not geo_obj.is2D:
+ self.c_mapinfo.contents.head.with_z = 1
+ self.c_mapinfo.contents.plus.with_z = 1
+ self.c_mapinfo.contents.plus.spidx_with_z = 1
          result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
                                           geo_obj.c_points,
geo_obj.c_cats)
          if result == -1:
Ticket URL: <Making sure you're not a bot!;
      Cpu: Unspecified |
Comment(by zarch):
Thanks to look into it!
I have 2 doubts:
* I'm not sure if it is correct to silently switch the vector map from 2D
to 3D when the user try to write a geometry feature. Maybe we should move
the patch from the write method to open (in abstract/Info), in this way we
don't have to check if the geo_obj.is2D for each call to the writing
method and user have to open the vector map explicity with 3D enabled. So
user could write something like:
with VectorTopo("new3D", mode="w", is2D=False) as vect:
     vect.write(Point(10, 20, 100))
Actually I don't like too much the is2D parameter in the open method,
perhaps is3D could be clearer, but we should change the attribute of the
geometry features from is2D to is3D for consistency.
* Do you know if there is a function in the GRASS API to enable 3D on
vector map instead of directly modifying the c_mapinfo structure? If not
your approach it looks fine to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320#comment:1&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:1 zarch]:
> I have 2 doubts:
2D to 3D when the user try to write a geometry feature. Maybe we should
move the patch from the write method to open (in abstract/Info), in this
way we don't have to check if the geo_obj.is2D for each call to the
writing method and user have to open the vector map explicity with 3D
enabled. So user could write something like:
Yes, that's much better.
Yes, I definitely agree, is3D would be much more intuitive.
Probably we don't need to change 2D/3D, user specifies 3D when opening the
vector map and there is already a parameter for that in
```Vect_open_new```.
See also the other ticket (#2311) which deals with reading 3D points from
a vector map.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320#comment:2&gt;
      Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:2 annakrat]:
> > in the open method, perhaps is3D could be clearer,
> > but we should change the attribute of the geometry
I didn't change that part for now...
> 3D when opening the vector map and there is already a
> parameter for that in ```Vect_open_new```.
ok, done.
Now you should be able to create a 3D vector map with:
with VectorTopo("new3D", mode="w", with_z=True) as vect:
or using the with_z parameter with the open method:
vect = VectorTopo("new3D")
vect.open(mode="w", with_z=True)
vect.close()
I did some tests and it seems to work, let me know if you have problems.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: pygrass
  Platform: All | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Thanks a lot, it's working for me now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320#comment:4&gt;
